Here's the deal.. My gas milage has fallen through the floor in recent months.. For now, it is a stock LT1, and I am getting ~10mpg city, and maybe 16-18mpg on the freeway.. I have the 3.07 gears.. and I know this is TERRIBLE gas milage. I have checked the injectors, and they dont seem to be leaking, besides, I dont think a leaky injector or two would have this big an impact on my gas milage. What other things could be causing this? O2 sensors?? I am doing heads and cam in about a week, and want my car to be running well afterwords.. What should I look for?? How much are O2 sensors, and where can I get them??
I am only getting about 14-16 miles per gallon overall. I thought that was about right. Am I wrong? I had the injectors cleaned, via additives, pressurized cleaning. Is it possible that it is just my driving habits in town?
When my 88 was running, combine mileage ~19-21 mpg driving from home to work. Strictly highway ~23-24.5 mpg at ~70 mph. I don't gun the engine for those mileage. When ever I drove down to Philly, the mileage drop to ~17mpg, probably because more stop and slower traffic.
You didn't install one of those IAT bypass "kits" did you? It amounts to nothing more than a 4.7K ohm resistor put across the plug of the IAT lead after you unplug it to supposedly fool the computer into richening the mixture. Some jerk was selling them on eBay $9.00 and I bought one for my L98. After installation my car ran "bubbery" (is that a word) and was getting 8.6MPG according to the computer.
Even if you aren't as stupid as I was and did this, there might be a problem in that area on your LT1 because I know that screwing with that sensor can kill your mileage. And it wouldn't show up as a trouble code.
From: And on the fifth day, subpoenas were served to Obama senior staff
Re: Major gas milage problems.. (MarkLT1)
Sounds like you have a problem.
Sources of poor gas mileage: Dirty Air filter, exhaust leaks before O2 sensors, bad O2 sensors, fuel pressure too high, clogged cat(s), bad ecm tuning.
Looking at your mods:
high pressure fuel regulator, SLP shor(t)y headers
I would check for leaks in the headers at any point and check fuel pressure.
I don't think O2 affect gas mileage. Beside if your O2 has problem the engine light would come on.
O2 sensors control mixture, they effect mileage directly. O2 sensor has to about fall off the car to cause a code! A very common fail mode is to get "slow" which will effect mixture and often not set any codes. Also the air vent on the O2 can become clogged with debris which will render it useless, and again may not set a code.
