I recently changed my entire exhaust system and want to sell the Side Effects side pipes I used to have on the car. If anyone is interested let me know I don't have the fiberglass covers, but I do have all the parts necessary to get the system mounted and working, they sound great!
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
list in the parts wanted/for sale. You must also list a price. Pictures too if you want to sell
Curious with so much demand why isnt this kit being recreated.
also why are the pipes all convuluted and long.
why not just simple exit shortest path possible with some bullet mufflers ? And that would reduce weight vs stock system which has pipes / big mufflers hanging past the rear axle
(ie. You arent buying this system bc you want quiet)
Most likely the tooling used for the castings were made for the particular casting machine that their vendor was using. Usually (but not always) casting tooling is not swap-able between different casting machines. So there is the not insignificant cost of having the tooling adjusted or redone from scratch depending on just who owns the rights to the tooling itself.
