hot 15 amp keeps blowing /CTSY/CLK in fuse box
hot 15 amp keeps blowing CTSY/CLK in fuse box
I leave my C4 1987 coupe in storage at times with a on board charger, Car starts everything is good with that, but everything thats on that circuit do not work (blue 15 AMP CTSY/ CLK),hood lights,horn,heat/ac blower,radio,dome lighths ,antenna.cig light.Possible relay blown,or ground out but where any one of these in the list? Cig light? Everything has been working for years until 06/28/15 upon startup i notice hood lights were out then checked fuse box new 15 amp fuse will blow out right away.
CAV.
CAV.
It's going to take some testing to find the problem.
Check out the fuse details from my 86 service manual.
http://dankai.shawwebspace.ca/asset/...ck_details.pdf
It will at least let you know what areas to look for the problem.
Good luck
Good luck
Fixed
Good luck
Good luck
CAV87
