Car Overheating?
Old Jul 16, 2015 | 04:55 PM
detomaso55's Avatar
detomaso55
Cruising
Default Car Overheating?
Hi Everyone,
This is my first post as a member so I apologize for my ignorance. I just bought a '94 LT1 coupe w/auto tranny and when I was in stop and go traffic, the engine temp needle seemed dangerously high. I didn't know there was a digital gauge until today so I dont know the exact temp it was running at.
My questions are as follows
  1. What is normal operating temp and what is considered too hot??
  2. I have read that turning on the AC actually helps cool the engine on these cars. Is this true?
Thanks in advance! I've never driven a car that ran this hot so I'm a little concerned.
Old Jul 16, 2015 | 05:15 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by detomaso55
Hi Everyone,
1. The fans come on at 228 and 238
2. Yes
Best to pull the top radiator shrould off and give a good cleaning. Give it a good flushing by pulling your knock sensors.
Old Jul 16, 2015 | 05:26 PM
detomaso55's Avatar
detomaso55
Cruising
2. Yes
Thanks for the reply!
Is it noticeable when the fans turn on? Should I be actually able to hear them turn on? I just want to make sure that they are actually turning on and working properly.
Old Jul 16, 2015 | 05:31 PM
L98Justin's Avatar
L98Justin
You should hear or feel them kick on, i would let it idle in the drive way to ensure both kick on when they are supposed too... try cleaning in the radiator shroud first its free and beneficial C4's are plastic bag eaters
Old Jul 16, 2015 | 05:59 PM
markKlein's Avatar
markKlein
Running in the 220s all day is fine, as designed.
Also, the analog gauge isn't really linear, so the needle looks higher than the reading really is. On the C5s they "fixed" this problem by making 220 read straight up on the gauge. That way is doesn't scare people by looking too far to the high end.
Old Jul 17, 2015 | 11:41 AM
tenaus's Avatar
tenaus
2. Yes
Before you pull the shroud off I would aim a flashlight between the radiator and the ac condenser, where the ac lines go in, and see whats inbetween them, leaves twigs etc. I attached a piece of PVC to my shopvac and vacuumed out everything I could using the space where the ac lines go in.. Did a pretty good job and it's much easier.
I ended up putting in an aluminum radiator anyway. Mine is a 94 lt1 convertible.
A lot depends on how mechanically inclined you are.
To Car Overheating?
