Progress Update
Old Jul 17, 2015 | 12:56 PM
89L98TPI's Avatar
89L98TPI
Default Progress Update
I'm sure most won't care but figured I'd show some of the progress I've been making installing my new engine and Single plane intake with Elbow. Lots of bolting and unbolting going on under this hood!! Some wrench flying and curse words also trying to make everything fit but she's mostly together now. Enjoy!
Old Jul 17, 2015 | 11:01 PM
l98tpi's Avatar
l98tpi
Max G’s
Looks like you are doing a nice job. I am interested in the HP/TRQ curve with this set up. Keep us posted.
Old Jul 18, 2015 | 08:19 AM
89L98TPI's Avatar
89L98TPI
Thanks. First time doing most of this so just taking it slow.
The engine was ran on a engine dyno a few weeks back. We were able to use my intake but unfortunately they weren't setup to run EFI so a carb was used for fuel.
Old Jul 18, 2015 | 09:05 PM
blackozvet's Avatar
blackozvet
nice work Ron !
I see that you used a Weiand remote housing ?
very neat job and that setup (fuel and water) should work well, are you going to use a thermostat in the housing ?
Old Jul 19, 2015 | 09:59 AM
ghoastrider1's Avatar
ghoastrider1
interesting set up. Great tourque numbers. Love to be in that thing in a 1/4 mile run.
Old Jul 19, 2015 | 10:07 AM
89L98TPI's Avatar
89L98TPI
Originally Posted by blackozvet
nice work Ron !
Yes its the Weiand housing being fed by (2) -12 lines. Other side of housing has CTS and heater core return plumb to it.
As far as tstat I will try one first and see what happens. It may cool fine without one like yours.
Old Jul 19, 2015 | 03:01 PM
jay1055's Avatar
jay1055
Attachment 47901041
Attachment 47901042
Attachment 47901043
Attachment 47901044
I like keep the updates Coming. Jay
Old Jul 20, 2015 | 05:56 AM
blackozvet's Avatar
blackozvet
the -12 lines should flow plenty, Im having no trouble with -10 lines.
if you have your coolant temp sensor in your remote housing then there is probably a greater chance that the thermostat will work correctly.
I was thinking about testing my system by using lower temp thermostats (around 160) to see if it would open when the CTS was reading around the 180 mark, because my CTS is still in the front of the manifold.
Old Jul 20, 2015 | 02:06 PM
rklessdriver's Avatar
rklessdriver
Looking good!
Old Jul 20, 2015 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
383 ?
Old Jul 20, 2015 | 04:58 PM
89L98TPI's Avatar
89L98TPI
Originally Posted by AGENT 86
383 ?
Thanks. Yes its a 383.
Old Sep 5, 2015 | 04:41 PM
yedister's Avatar
yedister
Sweet, the braided lines that goes by the back of the alternator needs some insulation from contact with the nut. Just in case.
To Progress Update
