1986 corvette tps problems can only get .42 volts new iacv new tps and complete tune up on trottle body new gaskets can someone please help
I'm not 100% sure, but I'm thinking the TPS minimum voltage spec is .54 +/- .075 VDC - worst case, minimum should be .47V. I'm not familiar if the TPS on an 86 is adjustable like my 85, but if it's not, you may be able to get some very minor adjustment just due to the mounting hole(s) tolerance - ??? - or if the TPS has adjusting slots, it should be a simple adjustment. one other thing I have to ask, how are you getting your readings - digital volt meter, analog, and how accurate is the reading. is the .42V you're getting affecting the drivability of the car? the .42V does seem a bit low, but on the other hand, my 90's TPS min voltage was .67V, and it didn't seem to cause any issues. I was able to get some minor adjustment by bending the tab on the TPS itself, but I was really never happy with that. I did however, replace it with an earlier design that had full adjustment capabilities.
What reading do you get when you open the throttle to maximum? It should go to at least 4 volts.
How are you measuring the TPS voltage? You should be measuring between the middle and bottom wires on the TPS connector. DO NOT use engine metal as the ground point for your meter. [ EDIT ] I screwed that up. I relied on my memory, which is obviously not as reliable as I thought. Measure between the middle and TOP wires. [ /EDIT ]
For reference, you should measure approximately 5 volts between the top and bottom TPS wires. That 5 volts is a reference voltage that comes from the ECM.
Reason: Added corrected information.
Are you sure i always tought its from top wire and middle wire thats the way i was checking it and only getting. 42 volts
Ground 1 end of the DVOM and touch the 3 wires, one at a time till you get 5 V. That is your reference. Now you have 2 wires left. Key on, Engine off, tweak the throttle and touch the other 2 wires. As you increase throttle, you get more voltage through one of them. Should start at about 0.5V. That is your signal to the ECM. Last wire is ground.
