Hello everyone. I posted this in the wrong forum before. I couldn't figure out how to move it so I'm posting it again here.
I want to purchase a 400" SBC and bolt on my heads, intake, headers and exhaust to it and get a retrofit roller cam that would be good up to 6000-6500 RPMs.
My 350 put down 344 rwhp 343 rwtq running slightly rich on the dyno and has the following mods: Miniram, 58mm throttle body, AFR 195 Eliminator Heads, Hooker Long tube 1 3/4" headers, Corsa true dual 2 1/2" exhaust with H pipe, flat tappet cam (224*/224* @ 0.050", 0.528"/0.528" with 1.6 roller rockers, 112* LSA) 10:1 compression, MSD 6AL2 ignition box.
So what I want to know is about how much HP I can gain by going to the 400 with a matching retrofit roller cam and porting out the Miniram a little bit more?
Can't comment on HP as I know nothing about the limits of a Mini Ram.Make sure you drill the steam holes in the heads for a 400.
I would wager a larger cam and more lift to take advantage of the AFR heads.
If you build the engine with the necessary parts to achieve the same rpm band as the 350 ran it should have a power increase about the same as the displacement change. So 344 should go to 393 rwhp. That being said a mini ram 400 running to 6500 rpm with the correct combination of parts should easily make 400 plus hp to the tires.
