No code C12
Old Jul 31, 2015 | 04:42 PM
1993C4LT1's Avatar
1993C4LT1
Default No code C12
I was checking for codes today, and got no C12. I have codes h72 and h74. I belive are the VATS and radio. Back then, I would get code C12 at the beginning every time. Does this mean something is wrong with ECM or PROM?
Car is a 93 lt1
Old Jul 31, 2015 | 05:12 PM
MARKRUBYRED's Avatar
MARKRUBYRED
You have H = History codes. If you don't have any problems, no trouble lights in the DIC and SYS is not flashing then I would not be concerned. I have a GM Tech 1 with MSC could read and clear the codes for you if you are in the Baltimore, MD area.
Old Jul 31, 2015 | 06:00 PM
TLS_Addict's Avatar
TLS_Addict
Car is a 93 lt1
I had an H code and my C12 never showed. I cleared that and BAM! The C12 code came up you should be fine as stated if no other things are flashing.
Old Jul 31, 2015 | 06:37 PM
1993C4LT1's Avatar
1993C4LT1
Ok, thanks a lot guys. Mark, I'm in Dallas. But thanks for the offer! My car feels like it's not running on all 8. Ran perfect yesterday. Starts up weak on cold starts, sometimes it would stall. I pulled two plugs on driver side, one was oil fouled. Think it's due to bad valve stem seals. Very little amount of blue smoke on start up, I'm talking very little. Sometimes I hate this car And no, there is no SEL light
Old Jul 31, 2015 | 08:42 PM
MARKRUBYRED
Gotta ask the question, how many miles on the LT-1?
Old Jul 31, 2015 | 08:50 PM
antfarmer2's Avatar
antfarmer2
Try a ohm meter on the injectors and check the fuel pressure and post the results a noid light too
Old Jul 31, 2015 | 09:48 PM
1993C4LT1's Avatar
1993C4LT1
To No code C12
