Courtesy Light Nightmare
Old Aug 12, 2015 | 05:28 PM
Pwnage1337's Avatar
Pwnage1337
Default Courtesy Light Nightmare
Guys help me out here.
1985 Corvette,
Interior lights stay on all the time.
From my research I found that its either the door switches, or the timer/dimmer module.
I read that I would be able to bypass the module and only lose the timer function, which I am an entirely OK with, so I did just that.
The lights still stay on all the time.
I replaced both door switches, and disconnected my hatch switch with both doors closed, lights still on.
Do I have a short to ground somewhere?
From my understanding the white wire is always hot from the CTSY fuse, and the switches ground when the doors are open, completing the circuit and lighting the car up.
So by bypassing the module, All I would need to turn the lights on is a ground. If my switches are new, and the hatch is disconnected, I must have an open ground somewhere?
Thanks for any input!!
Jeremy
Old Aug 12, 2015 | 07:10 PM
WVZR-1's Avatar
WVZR-1
HOW DID YOU ATTEMPT TO DO THIS?
THIS IS INCORRECT - PINK/BLK or ORANGE IS A CONSTANT POWER TO THE LAMPS, THE WHITE WIRES GO TO THE CONTROL DEVICE (in this case the dimmer module), which passes it on to the DOOR SWICHES
Jeremy
Do you have a FSM? Seems likely not or you wouldn't have asked these questions OR you don't understand it.
If you have a FSM look in the vicinity of 8A-114 maybe for the INTERIOR LAMP functions. I don't have but it should be similar ALL YEARS.
I believe I can supply a diagram if needed that should be correct.
Old Aug 12, 2015 | 09:09 PM
Pwnage1337's Avatar
Pwnage1337
I do have a FSM, I couldn't find it in my manual anywhere. I didn't check the supplement book that came with it though, I'll check it now.
Old Aug 13, 2015 | 12:46 AM
Cliff Harris's Avatar
Cliff Harris
Have you got the headlight switch turned to the "courtesy lights on" position?
Old Aug 13, 2015 | 08:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Jeremy
The white wires are the grounds. Your bypass would be joining the 2 white wires from door jam switches and the white that goes to interior lights.
From my 86 service manual
http://members.shaw.ca/dankai/Interior%20Lights.pdf
Chances are good
Old Aug 13, 2015 | 09:07 AM
WVZR-1's Avatar
WVZR-1
Chances are good
I thought it might be interesting to see his approach to bypassing the timer. Someone obviously suggested the method to him OR .... Regardless if it's something that was suggested here on the CF and it DOES NOT work then if corrected here it could save the aggravation for anyone else that might happen to stumble upon this thread. Maybe the other thread if that's where the OP got his information needs "amended".
The light switch rod? I try to give ALL the benefit of doubt.
The FSM excerpt you posted is the same as what he should find in his FSM when he looks. The location in ALL FSM's should be indexed similarly.
Old Aug 13, 2015 | 02:17 PM
Pwnage1337's Avatar
Pwnage1337
Thanks for the help guys, gonna tackle this today after I finish doing brakes on my Gma's Buick.
It is in my FSM, in the "manual supplement" Should have looked there!
And no...my headlight switch isn't in the "courtesy light on position" LOL
Old Aug 13, 2015 | 03:04 PM
Pwnage1337's Avatar
Pwnage1337
Just went out and bypassed the module, the white wires are jumpered together and now my lights go on and off with the doors opening/closing. This can be done without any cutting of the harness, just take a jumper wire from white-white. I used two "open barrel crimp" connections, both male. They are in there pretty snug.
Not sure why on the other website I read it told me to take the black wire to the white wire....White to white is the correct way to do it.
Thanks guys!!!
Jeremy
Old Aug 13, 2015 | 10:50 PM
70chev's Avatar
70chev
Hi Jeremy,
Have you got any photos of the "fix". Many would be interested I would think.
Darren
Old Aug 14, 2015 | 05:13 AM
Pwnage1337's Avatar
Pwnage1337
I can try to get some, it's pretty tight in there
Old Oct 16, 2015 | 07:05 AM
occupa's Avatar
occupa
Any luck on the photos?
Where is the timer module?
I have similar problem.
The lights do not turn on with the door open, however the do turn on with
the hatch
and the headlight switch.
What do you think?
Old Oct 16, 2015 | 08:37 AM
GQ-ROD's Avatar
GQ-ROD
There was a TSB on bad door switches which corroded, they improved the door switch design in later years.
The hatch switch has a plastic rod with a tab that breaks leaving the rear ctsy lights on in cargo area, found this out when my lights stayed on one night.
Use a test light to check for shorts to ground, this is the easiest way to find which wire has the short.
Old Oct 16, 2015 | 11:25 PM
Cliff Harris
It's taped to the heavy wiring harness that goes to the fuse block, close to the fuse block. There is a diagram in the FSM that shows the location.
Old Jul 11, 2016 | 10:28 PM
sanham's Avatar
sanham
7th Gear
Thanks guys!!!
Jeremy
Jeremy... did you have the chance to take pictures??? or may have them somewhere around... i have the same problem and can't fix it...
thanks...... or if you can give me some more info about where and how... will be great... thanks for your time
Old Jul 13, 2016 | 06:23 PM
gerardvg's Avatar
gerardvg
Hi
Have you tried to replace the board ? they are quite cheap.
I have had to replace my courtesy delay timer a couple of times in the 20+ years I have had my 85, they just fail at any time like a light bulb.
sometimes the lights don't work other times they stay on.
Anyway the shop manual is a must when you have a C4, the diagnostics and wiring diagrams are very helpful.
http://www.parts123.com/corvettecent...50f&ukey=29596
To Courtesy Light Nightmare
