Persistent AC Compressor Leak
The frustrating part is that if I get it to stop leaking from the high side seal, the low side seal will leak. If I fix this, the high side seal starts leaking. Tightening the bolt on the connector as tight as humanly possible, as well as using a rubber hammer to move the connector around a tiny amount helps to reduce the leak, but its always present in some place.
I've replaced the seals at least 3 times, but its the same problem. I use a sealing washer for the low pressure side, and the thicker seals for the high pressure, as I found on the compressor originally.
If anyone can help me out, you'd have my eternal thanks. Florida's sun is particularly unforgiving this time of year. Thanks in advance!
In this post there's two links to sealing systems. The second will take you to a .pdf of actual sized product. You will have to scroll through the link to the R4 seals.
https://www.corvetteforum.com/forums...post1590205103
You may have a bend or CRACK in the aluminum part of hose assembly that bolts on to your compressor, use a ruler or straight edge to check if it is straight. Look with a magnifying glass that it is not cracked.
If it is bent or cracked replace it, if not check the a/c compressor body recess where the O rings go, make sure there are no nicks or cracks.
Lubricate the new O rings with refrigerant oil, Check the O rings sit proud of the recess they need to be fairly thick.
Carefully fit the hose bracket and there is no need to over tighten the bolt.
Pressure test it and use soapy water (water with nice thick dishwashing liquid) and look for any leaks
New from corvette central. $120
http://www.parts123.com/corvettecent...050f&ukey=8495
New from Ebay.
http://www.ebay.com/itm/1985-1987-C4-A-C-Compressor-Line-Hose-to-Condenser-USED-Corvette-/121722066705?hash=item1c57335711
Second hand from ebay... try your luck ...?
http://www.ebay.com/itm/Corvette-C-4-1985-1986-1987-air-conditioning-AC-dryer-hoses-as-pictured-/252042555889?hash=item3aaee831f1&vxp=mtr
New compressor o rings.
http://www.parts123.com/corvettecent...50f&ukey=18023
You may also be interested in the retrofit kit with new seals?
http://www.parts123.com/corvettecent...50f&ukey=47360
I don’t have the specific information at this time, but from what I remember there are 2 different kinds of seals. One is a round O ring, and the other is a flat washer type seal. If the wrong one is used it will not work or seal correctly.
I will see if I can dig out the specific information in my past threads.
As of right now, its been 3 or 4 days and my AC is still ice cold. I noticed that if I turn the AC down (from Max to Normal), the refrigerant doesn't noticeably leak. At Max (which I kept it on, and used to charge the system), the seal can't seem to hold. I also found it weird that the system held vacuum perfectly for an hour without leaking. I wonder if the seals are just not rated for that kind of PSI, or maybe there is a tiny imperfection in the metal that is exposed at that pressure?
I'm going to check the compressor and make sure I'm using the proper seals, and post my findings here. In the meantime, I'm going to enjoy the AC I have until it finally leaks out. When it does, I'll thoroughly inspect the surfaces, throw on the proper seals, and try again....
By the way, I'm sure it would make any difference, but my system has already been retrofitted to 134a. Just adding that detail in...
