I have an 88 coupe auto. It has 50k miles. Shift kit , open air filter cover , removed pie plate, magna flow exhaust with no cats and factory manifolds. What horsepower and 1/4mile time could be expected if I decided to do the above combo?
You dont have full exhaust. Factory manifolds are the bottle neck. Cat backs save weight and give sound. Without manifolds being swapped you won't make more power. Simple as that.
Get some long tubes and tuned and you will make more power.
When my 91 was stock it ran 14.0x at 99 or so. With exhaust mods similar to your's (front y-pipe w/out cats, hollowed main cat and aftermarket cat-back) it went 13.80 or so. Its been quite a few years, but IIRC deleting the cats was the biggest gain although, as others stated, I can't say for sure if this was due to my cats being clogged.
Stock manifolds are fine for a stockish-mild engine, people over header c4's a lot! Until you make over 400hp I wouldn't even think of 1 3/4 headers. If you look at the stock racing classes some of those guys that really fine tune those best stock parts you'll see they got a 1 1/2 primary and making around 350-375hp.
ADA the same? A DA change can result in half second time differences with the same set up. Also depends on track prep.
Without seeing a slip, the ET to me doesn't mean much. If its all in the 60 foot, its due to hooking better.
