96 c4 rough idle
Old Aug 15, 2015 | 02:00 PM
etcopy1's Avatar
etcopy1
Cruising
Default 96 c4 rough idle
I have a 96 lt1 that has a rough idle in park and drive. I have taken it to multiple shops and everyone is scratching their heads. It has had new oem plugs and wires, fuel filter, pressurized fuel cleaning service, compression and vac lines checked, valve springs checked. Fuel injectors swapped from one position to the other, and the code did not changeto another cylinder. Only thing it shows in diagnostics is a misfire in cylinder 3. This was the case even before all the work was done. Timing and spark are reading correctly according to the mechanic.
Any ideas? Optispark?
Old Aug 15, 2015 | 02:08 PM
antfarmer2's Avatar
antfarmer2
The spark wires must click twice good chance you have two swaped. Get a noid light and make sure #3 is getting power might just be a nibbled injector wire.
