Follow up to me overrevving/locking engine
Old Aug 16, 2015 | 05:24 PM
volkswagens-for-life's Avatar
Default Follow up to me overrevving/locking engine
If you are confused, see here: https://www.corvetteforum.com/forums...d-a-valve.html
Well I took the vc's off today. When this all happened, I *thought* it seemed like the pass-side is where I heard the 'bearings in a Folgers tin can' sound. Evertying looked fine under the VC's except one thing. ON the passenger side, second piston back from the front, the right rocker (which make make it the third rocker in from the front) is cranked wicked high. As in, the spring is super compressed, and the pushrod side is super high up. It appears way higher than any other rocker on the motor right now. Here is a pic. Where do I go next?
Passenger side, second piston in, third rocker arm in. Running wicked high.
Old Aug 16, 2015 | 07:25 PM
rklessdriver's Avatar
rklessdriver
Broken valve. Pull the plug out of that cyl... probably bashed to ****.
Will
Old Aug 16, 2015 | 07:40 PM
DanielRicany's Avatar
DanielRicany
Hard to see but it looks to me like the valve spring on the affected rocker is the same height as the neighboring spring. Maybe something with the pushrod, lifter, or cam?
Is the rocker arm loose?
Old Aug 16, 2015 | 08:18 PM
I'm thinking a broken valve too. Over revved it. Floated a valve. Piston smacked valve. Ate valve. Tossed it around the cylinder on the way down. Then locked the motor.
Spring and rocker seems tight enough. No different than the others. Can't figure out why my double spring setup allowed a float though?
What's the next step?
Old Aug 16, 2015 | 08:29 PM
DanielRicany
Remove the two rockers and do a leakdown test.
Old Aug 16, 2015 | 09:02 PM
Didn't mean to ignore the other reply. I'll pull the plug and analyze. Leakdown without the rockers how?
Old Aug 16, 2015 | 09:28 PM
jv9999's Avatar
jv9999
Just loosen the rockers all the way for that piston and pressurize it through the spark plug hole. It will probably leak so much that you won't really need a leak down gauge.
Old Aug 16, 2015 | 09:44 PM
Ohh Ok that makes sense. So do you also think that it's a broken valve? I'll try to get going on a leakdown. I think pulling the spark plug will tell a story too.
Can somebody tell me why the rocker would be full up on the pushrod end if the valve is broken?
Old Aug 16, 2015 | 10:26 PM
DanielRicany
A leak down test will tell you if the valve hit.
Old Aug 16, 2015 | 10:37 PM
A buddy suggested a rod bearing. The oil is clean...
Old Aug 16, 2015 | 10:57 PM
1055's Avatar
1055
hydraulic lifters? if one was under pressurized or collapsed, pushrod could have wiggled its way to the edge, then oil pressure forced it higher than intended.. giving you the oil derrick effect on the rocker arm?
Old Aug 17, 2015 | 12:48 AM
Hot Rod Roy's Avatar
Hot Rod Roy
You'll find the answers to your questions when you pull that head. You don't have any other choices! Have fun!
Old Aug 17, 2015 | 09:00 AM
ghoastrider1's Avatar
ghoastrider1
among other good news your getting, I bet that pushrod is now bent and wedged, keeping that rocker high.
Old Aug 17, 2015 | 11:13 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Will
That would be the first thing I would do.
Old Aug 17, 2015 | 12:22 PM
And then what?
1- The plug is smashed... proceed how?
2- Plug looks perfect... proceed how?
Old Aug 17, 2015 | 12:23 PM
All in a days work in the life of me
Old Aug 17, 2015 | 12:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
And then what?
Really?I'd think that "what would come next" would be pretty self evident, but...
Remove head. You know you've got a broken valve at least, so head HAS to come off. At worst, you've got a caved in piston.
Remove rockers from that cylinder, inspect. If all looks fine (push rod) valve spring, stem, etc) then do the above mentioned, "poor man's leak down test".
To Follow up to me overrevving/locking engine
Old Aug 17, 2015 | 01:37 PM
Pwnage1337's Avatar
Pwnage1337
Here's what you do-- Assuming you have a smart phone.
Amazon.com: 2 Million Pixels Cmos 5m USB Waterproof Hd 6-led Borescope Endoscope Inspection Tube Visual Camera: Industrial & Scientific Amazon.com: 2 Million Pixels Cmos 5m USB Waterproof Hd 6-led Borescope Endoscope Inspection Tube Visual Camera: Industrial & Scientific
Buy one of these, along with:
Amazon.com: niceeshop 90 Degree USB 2.0 A Female to Micro B Male Converter Host OTG Adaptor Cable: Cell Phones & Accessories Amazon.com: niceeshop 90 Degree USB 2.0 A Female to Micro B Male Converter Host OTG Adaptor Cable: Cell Phones & Accessories
That is if you have an android/non iPhone. Download an app called CameraFi.
Pull plug, shove borescope in there. See what you see. If you see shards of metal pull the head, the engines screwed.
If you don't. Pull the rest of the plugs and see which one is screwed. Lol
EDIT:
Dear mods,
Sorry if my links aren't allowed. I've used and abused my borescope at least 10 times in the 2 months i've had it, its a useful tool for almost anybody.
Delete my post if you will.
---Jeremy
Old Aug 17, 2015 | 01:55 PM
Thank you for the input guys. This weekend I'll dig deeper into it and I'll let you know what I come up with.
Old Nov 17, 2015 | 12:47 PM
Just as follow up.
Two weeks ago I began tearing the top end down. I didn't have to get very far, taking the runners off in fact, to realize there is massive chunks of piston within the system. The runners and upper intake have massive chunks of piston. I also noticed the cam was ******* off of the distributor gear.
Thats as far as I had to go to know that the motor is FUBAR. I appreciate everybody's input and help in this.
