MAF to MAP Conversion
Old Sep 5, 2015 | 12:50 PM
ABOVELANDER's Avatar
ABOVELANDER
Default MAF to MAP Conversion
Does anyone know of a company that can sell me a kit to upgradge my 88 Corvette from MAF to MAP?
Old Sep 5, 2015 | 01:23 PM
aklim's Avatar
aklim
I would think you'd have to do some reprogramming of the ECM and rewire stuff.
Old Sep 5, 2015 | 01:34 PM
dizwiz24's Avatar
dizwiz24
I would assume an upgrade would be going from map (speed density) to maf (direct measurement of airflow) and sequential fuel i jection.
Cant tell you how many times i wish i had map/ sequential on my 93.....
Old Sep 5, 2015 | 01:38 PM
aklim's Avatar
aklim
Wouldn't MAF have the additional piece to obstruct airflow? Now how much, IDK. Anyone?
Old Sep 5, 2015 | 01:59 PM
dizwiz24's Avatar
dizwiz24
Yes. Maf has a maf sensor in the intake ducting.
I have heard of guys converting to speed density who had plans to make insane horsepower (ex. 1000 hp )
For the rest of us thT street drive our cars, a maf provides an accurate direct measurement of air flow for best gas mileage and driveability.
In my personal case, ever since i did the hotcam mod, i get a nasty exhaust smell at idle. No amount of tuning can fix it.
Basically there is more intake/exhaust overlap reversion (with a more radical cam) where both intKe Nd exhaust valves are open at the same time and the o2s see false air making the car run rich.
Its my understanding the later model 94 sequential / maf cars dont has as much an issue with this nasty idle as i do when they do more aggressive cams
Ive tried an open loop idle but never could get it to work (always reverts back to closed loop for some reason)
Old Sep 5, 2015 | 03:15 PM
Corvette40's Avatar
Corvette40
MAP sensor, 7730 ECM and different O2 sensor. You'll have to find the 7730 connectors and re-pin your harness. You will need a new tune also.
Old Sep 5, 2015 | 11:47 PM
whalepirot's Avatar
whalepirot
Upgrade is a questionable judgement. Corvette used SD for two years, then switched back. I was advised that SD is much less forgiving of any mods, when I chose my system.
Old Sep 6, 2015 | 12:01 AM
pologreen1's Avatar
pologreen1
If it's a radical motor forget it. I had some of the best tuners on this board trying to make my '90 run my motor and no dice. Ended up with aftermarket.
Old Sep 6, 2015 | 12:40 AM
aklim's Avatar
aklim
I thought it was less forgiving but if you tune it, life is good?
Old Sep 6, 2015 | 12:42 AM
aklim's Avatar
aklim
How radical is radical? My tuner assured ne that they can tune a 383 which is blown.
Old Sep 6, 2015 | 02:37 AM
pologreen1's Avatar
pologreen1
Yes, they tune that combo all the time so that is probably fine.
On the other hand I did hear that a 383 6 spd had an issue in 6th gear at low speed and shuts down. Either way far as I know the stock computer works for what you are doing.
Old Sep 6, 2015 | 06:45 AM
aklim's Avatar
aklim
At what point, assuming a good tuner has the tools (sniffer, dyno, etc, etc), does the stock ECM become inadequate and we have to do something like an Accel DFI or Megasquirt, etc, etc.
Old Sep 6, 2015 | 09:51 AM
dizwiz24's Avatar
dizwiz24
Read my post. Trust me.....even Alvin tuned it in person (if you doubt my skills tuning)
All this said i have no experien e with maf, just ancedotal quotes that people with similR mods didnt have the sAme exhaust smell issues
Old Sep 6, 2015 | 08:55 PM
RWDsmoke's Avatar
RWDsmoke
I used the EBL Flash ECM from dynamicEFI. Easy swap using Original harness. Just move a couple of wires in the connector. I built a sheetmetal air filter housing with a 4 inch tube from the housing to the throttle body. Easy to tune yourself with its own software. All you need is a laptop. And a wide band o2 if you want to tune open loop yourself. It allows you to run open loop idle if you have a big cam. Supports 1,2,or 3 bar MAP sensors if you are running boost.
Old Sep 7, 2015 | 12:46 AM
pologreen1's Avatar
pologreen1
I can't answer that. I just know my '90 computer has a dead spot and all kinds of trouble. Tried a brand new one and no good.
It's strange. I know skidwnit was using a similar combo/ computer but he could tune his. His was out of a Camaro though if that matters.
Either way I want a supercharger in the future so I am fine with upgrading.
Old Sep 7, 2015 | 02:03 PM
tequilaboy's Avatar
tequilaboy
Considering recent maf developments, s/d conversion is no longer the only option for mid to high power tpi builds.
You may be surprised to see what can be done with a maf and the 165 ecm,
Old Sep 7, 2015 | 04:00 PM
whalepirot's Avatar
whalepirot
Life is damn good, with stock ECM (90 Camaro) and HEI. C6Zs only slightly faster.
To MAF to MAP Conversion
