optis suck!
Old Sep 15, 2015 | 03:56 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default optis suck!
Just put in the new Petris opti and the car ran great, went out 2 hours later to drive her for the second time since the change, started her up and it runs like crap its rough and surging, this crap is real fun. What the hell is going on I connected everything back up.
Old Sep 15, 2015 | 06:26 PM
93Rubie's Avatar
93Rubie
Yeah, there is a permanent fix. 24x EFI Connection systems or OEM opti-spark.
Old Sep 15, 2015 | 06:40 PM
aDigitalPhantom's Avatar
aDigitalPhantom
That or an LS Swap.
Old Sep 15, 2015 | 06:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
IDK... Doesn't get rid of the Opti wheel/sensor...the most problematic part of the Opti.
OEM might be a fix. Not saying "this is it", b/c I don't think that it is....but my NAPA unit has been in my car for over three years now. No issues so far.
Old Sep 15, 2015 | 07:04 PM
desertmike1's Avatar
desertmike1
That sucks big time, I don't blame you for being pissed!
Old Sep 15, 2015 | 08:13 PM
dizwiz24's Avatar
dizwiz24
It sounds like the problem is the new petris optisparks.
Its my understanding they dont use the mitsubishi optical sensor anymore.
Totlly understand your frustration.
I too have been victim of 'i just spent 3 hours to instll an opti and it runs for 2 minutes then shuts off. Wont restart until cool'
Got lucky and found An oem lightly used gen2 opti (with the tan cap even).
Works fine. No worries
Old Sep 15, 2015 | 09:52 PM
kimmer's Avatar
kimmer
It's good to hear that some of you got one that works more than 10 minutes. Well onward I go with the game. Bty don't buy a chandlers, it only lasted about 2000 miles but I guess that beats 6 miles. I just dont understand how it ran so good and after shutting it down and a restart 2 hours later it just went upside down.
Old Sep 15, 2015 | 11:07 PM
aDigitalPhantom
The 24x setup removes the opti, and adds the crank/cam signal to use the LS PCM, and CNP ignition.
Old Sep 15, 2015 | 11:38 PM
A95Y's Avatar
A95Y
Dumb question. With this setup, it would magnitudes easier to find someone to tune our poor old wrecks?
Old Sep 16, 2015 | 10:18 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You're RIGHT! My bad....I was confusing it w/the Delteq or what ever, that still used the opti for is pick up. Sorry for the bad post.
Old Sep 16, 2015 | 11:08 AM
GRKLGHTNG's Avatar
GRKLGHTNG
What is it with these aftermarket Opti's? Can none of these manufacturers build a quality unit? Is the failure rate of the Opti's one of the reasons why you don't see a lot of '90's B-body and F-bodies around any more?
Old Sep 16, 2015 | 11:46 AM
John A. Marker's Avatar
John A. Marker
Did something come loose? Seems like that would be the case. They should replace it.
We just bought the same thing for Lynda's 94. Goes in the 22nd for some testing just in case its not the OPTI. If it is then the Petris is sitting on my desk.
Old Sep 16, 2015 | 03:26 PM
dizwiz24's Avatar
dizwiz24
Im convinced the opti is not a bad design, just in a bad place.
Oem optis are fine - as long as they have a custom vent harness added on the 92 thru 94.
Howver its my understanding there are no gen 1 nos oem ac delco optis left.
Gen 2 i believe might still exist as delphi and be available but im not 100% sure. Need to confirm that the latest delphi units atill have the mitsubishi emblem on the optical sensor
Lastly ... Our cars run hot. Heat is bad for electronics.
Figure out a way to make the car run cooler and opti will live longer. For example i have a reprogrammed fans and 160 tstat. I never see over 180f vs stock where 220f was normal
The issue is on the aftermarket optispark is poor quality of the electronics (optical sensor) and sometimes poor assembly (warped reluctor disks)
Old Sep 16, 2015 | 04:02 PM
aDigitalPhantom
Originally Posted by dizwiz24
Figure out a way to make the car run cooler and opti will live longer. For example i have a reprogrammed fans and 160 tstat. I never see over 180f vs stock where 220f was normal.
I doubt temperature is part of the problem. My brother has a 94 Trans AM with a 95 LT1 that has about 170k+ on the original opti with just a cap, and rotor replacement. Factory thermostat temperature.
Last time I checked the PCM was sending the opti 1vdc, and when it ran the car had the symptoms of a bad opti. After some looking, and a new power source it has ran fine with no problems.
Another interesting fact I doubt people here will believe is that you can use a 4-pin HEI ICM in place of the LT1 ICM.
Old Sep 16, 2015 | 04:14 PM
dizwiz24's Avatar
dizwiz24
Didnt the f bodys get the gen 2 (with vent harnss) opti before the vettes?
I suspect that is a gen 2 opti on that f body
Old Sep 16, 2015 | 06:52 PM
STEVEN13's Avatar
STEVEN13
Would like to get more information on this. Can you then use a conventional distributor?
Old Sep 16, 2015 | 07:20 PM
aDigitalPhantom
The engine is a 95, so yes it is vented. He got a 95 Firebird Formula with an LT1/T56 that had been rear ended for about 1K. Then a 94 Trans AM, that someone bought for the drivetrain for $500.
Not if you want to keep the factory fuel injection. What I meant was you can wire it in place of the factory ICM, and it will work.
To optis suck!
Old Sep 16, 2015 | 07:24 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I believe it. They're both 4-pin "relays". What is the advantage to this, though?
Old Sep 16, 2015 | 07:27 PM
aDigitalPhantom
Here at least price and availability. The LT1 ICM is ~$90, and the HEI ICM is ~$30. Other then that not much.
Old Sep 16, 2015 | 07:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Ahhh, well that is certainly a sound reason. Copy that, and good tip! Thanks!
