Coolant correction spark
Old Sep 28, 2015 | 12:12 PM
Billygoatkid's Avatar
Billygoatkid
Default Coolant correction spark
Hey ,
Found something interesting when data logging. My 1988 Vette went to 20.04 spark advance and stumbled when I accelerated. This was the value in my cold spark bias. This value works with the table coolant spark correction . Right?
Now this table had temp values which are not marked Celsius or F. My car is Canadian so I'm wondering if the computer is reading in Celsius and the table is in F. Then it would never see that the car is warm. Pulling spark.
This make sense?
Old Sep 28, 2015 | 05:48 PM
DanielRicany's Avatar
DanielRicany
ECM sees C. Sometimes output is converted to F on a scanner.
Old Sep 28, 2015 | 05:49 PM
DanielRicany
You say your engine stumbled when you accelerated, did this start happening after mods? What are the mods? Maybe I can help you get rid of it.
Old Sep 29, 2015 | 12:41 PM
tunedport85inject's Avatar
tunedport85inject
may be your Knock sensor detected a noise and pulled timing when you stomped the gas pedal....just guessing....
Old Sep 30, 2015 | 02:31 PM
bjankuski's Avatar
bjankuski
That is the maximum amount of additional spark that can added to you main spark table based on engine temperature (20.04) degrees. The main spark table cannot accept any numbers less then zero so the spark bias table allows you to add or subtract any number up to 20.04 degrees from the base timing table. The main spark table plus the cool.comp.spark adv. vs RPM vs cool.temp table added together is your total advance.
Old Sep 30, 2015 | 02:45 PM
Billygoatkid
Thank you!
To Coolant correction spark
