So I noticed a power steering leak so I went and bought a bottle of Lucas power steering fluid leak stop. I filled my reservoir with about a quarter to a half of this stuff and topped the rest off with new power steering fluid but now I have a problem where something is grinding and screeching every time I turn my wheel, so I flushed out the leak stop fluid and refilled my reservoir to the "cold full" line and STILL the problem persists. Please help me! -Brandon
could it possibly be air bubbles/ air in the system. Maybe let it sit over night and let small air bubbles form to large ones and try turning the wheel tomorrow wheel lock to wheel lock?
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Trapped air. Raise the front end so the tires are off the ground. This makes it easier to turn the wheel. Now crank the steering wheel lock to lock with the engine off. After a few cycles check the fluid level. With the engine started turn the wheel slowly lock to lock. If the noise has stopped go for a test drive. If not repeat until those air bubbles are chased out.
