Replacing resonator w/ X-pipe
Old Oct 5, 2015 | 12:27 PM
JWASR64's Avatar
JWASR64
Default Replacing resonator w/ X-pipe
Who has done this, leaving the 2 mufflers at the back.
What is the sound change ?
I didn't find much in search.
Thanks in advance for any info. !
Old Oct 5, 2015 | 02:06 PM
TorchTarga94's Avatar
TorchTarga94
I had that setup on my 94' LT1. Sounds good, don't expect much change over the factory. It is a tad throatier and a bit deeper. Still no drone just like the stock system.
Power difference? Negligible.
Old Oct 5, 2015 | 03:18 PM
JWASR64's Avatar
JWASR64
I seen people using different sizes. What size openings would be needed for the stock pipes on a 95 ? 2.5 " or 3"
Old Oct 5, 2015 | 03:27 PM
TorchTarga94
Go with a Flowmonster 3" X-pipe. Fit the tunnel perfectly. The stock pipe size is 2.75".
http://flowmonster.com/i-6477690-fmx...ce-pipe-3.html
Not the best pic of my old system but will give you an idea:
Old Oct 12, 2015 | 03:27 PM
Dr_Shakalu's Avatar
Dr_Shakalu
What year car do you have. This isn't exactly what you asked for but this is my 96 auto coupe with an x-pipe and no mufflers. Just the pipes ending through exhaust tips. I first just had my mufflers removed but the droning inside would give you a headache after 5 minutes and forget about having a conversation. After adding the x-pipe, what a difference that made. Sounds great outside and I'm able to have a quiet conversation inside. The resonator is kind of like a muffler. Inside the resonator is a tube with holes that makes the exhaust gases bounce around inside and then exits the resonator. The gases bouncing around in the resonator causes a lot of drone without mufflers. The x-pipe smooth's the gases out which allows the gases to exit quicker.
This the x-pipe I'm using.
Amazon.com: Lawson Industries 66925 Stainless Steel Stamped X-Pipe: Automotive Amazon.com: Lawson Industries 66925 Stainless Steel Stamped X-Pipe: Automotive
This is how my car now sounds. I know you want to keep the mufflers but just wanted to give you an alternative. Good luck!
Old Oct 13, 2015 | 12:02 PM
JWASR64's Avatar
JWASR64
Thanks for all the info.
Mine is a 95.
Old Oct 13, 2015 | 03:01 PM
Decat's Avatar
Decat
Well I went with the Melrose ceramic coated long tube headers to hi-flow cats to X-pipe, to dual magnaflows, and I absolutely love the sound.
I had factory before that, and then I went to factory with muffler deletes and it was just a little too much, but the long tube headers with X-pipe is exactly what I was looking for!
Good luck!
Old Oct 13, 2015 | 04:47 PM
Ron B C4's Avatar
Ron B C4
Good luck!
Any problems with drone? I have the Melrose headers waiting to put on. MagnaFlow complete system with the resonator. Been debating about getting the Melrose X.
I'm guessing the high flowcats will muffle it a like the resonator.
Old Oct 13, 2015 | 08:47 PM
BucfanTitan's Avatar
BucfanTitan
I have the x pipe and stock mufflers on a 95 it is great. Gives the car a nice deep throat sound. Purchased and installed for under 100. I have the Lawson from Amazon.
Here is the link I posted on the forum with pictures and a video in the threads. Enjoy you will like it
https://www.corvetteforum.com/forums...install-2.html
Old Oct 13, 2015 | 11:29 PM
MatthewMiller's Avatar
MatthewMiller
Previous owner of my car (MSR) went through extensive engineering to properly place an x-pipe in my car. It has cats after the x-pipe, and mufflers at the very back. It's pretty loud, and it hits the x-pipe rasp very obviously in the second half of the rev range. I'm not really a loud-car kind of guy, but damn it sounds awesome!
It did improve the power compared to true duals. But the key to getting an increase with an x-pipe is to have no expansion chamber components ahead of it. That means no mufflers, resonators, or cats. Nothing. Everything after the first expansion chamber point is just a matter of reducing restriction - there is no resonant tuning to be had downstream of that first chamber.
Old Nov 23, 2015 | 05:08 PM
Decat's Avatar
Decat
Yes, terrible drone from 65-80 mph. Magnaflow drones like crazy. I am still debating what to do to fix this. I would like to keep the Melrose Long Tubes, Hi flow cats, and X-Pipe, but what muffler should I put on the back to eliminate the drone?
Old Nov 24, 2015 | 11:52 AM
TorchTarga94
Stock Mufflers, Corsa, Dynomax
To Replacing resonator w/ X-pipe
