1987 What's this gizmo-
Old Oct 18, 2015 | 09:04 PM
Tom454's Avatar
Tom454
Default 1987 What's this gizmo-
This was attached to a stud off the oil pan rail... but nothing was attached to it...
Old Oct 18, 2015 | 09:55 PM
bjankuski's Avatar
bjankuski
It is a mount for some of the engine wiring near the pan. Look for the wiring by the pan and see if there is a plastic push connector that could fit through the hole.
Old Oct 18, 2015 | 10:37 PM
WVZR-1's Avatar
WVZR-1
I believe Cliff mentioned that last week and if it's from the left side rail then there's likely a rose-bud that secures the transmission wiring to that bracket. Not a connector but a retainer for the conduit.
If it's on the right side rail near the starter then it's likely the same sort of support for the conduit that contains the knock sensor wiring in the block and the fan/temp sender in the cylinder head.
Old Oct 18, 2015 | 11:50 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
It may also be a bracket attach for the factory oil cooler H20 lines
Old Oct 19, 2015 | 04:48 AM
WVZR-1's Avatar
WVZR-1
I do believe this is correct. In this link/image it's likely #12 and maybe actually only on models through '88 which seems odd.
http://www.wholesalegmpartsonline.co...rimLevel=25296
Old Oct 19, 2015 | 06:00 AM
Tom454's Avatar
Tom454
It's on the drivers side, 3rd oil pan hole from the rear, 7th oil pan hole from the front. There is no oil cooler (or any remnants)... so I'm thinking it's a wiring retainer. Thanks.
Tom
Old Oct 19, 2015 | 07:37 AM
ex-x-fire's Avatar
ex-x-fire
On my 84 it supports the o2 sensor wiring.
Old Oct 19, 2015 | 09:06 AM
WVZR-1's Avatar
WVZR-1
And the possibilities continue. If it's this bracket this "rose-bud" is likely a correct fastener to put it back the way it was.
GOOGLE IMAGES are your friend here:
8917236 GM
To 1987 What's this gizmo-
