Sway bar link/bushing replacement
Old Oct 23, 2015 | 11:43 AM
JWASR64's Avatar
JWASR64
Default Sway bar link/bushing replacement
I think I have the base suspension, what is the code for that ?
EF1 ?
On the replacement bushings what material do you prefer ?
Lastly do the large mounting bush on the sway bay slide on the
bar from the end, or do they have opening that are held closed by the bracket ?
Thanks.
Old Oct 23, 2015 | 11:56 AM
WVZR-1's Avatar
WVZR-1
EF1 ?
Thanks.
FE1 is base and the bushing to the frame rail is split with the clamp (you called it bracket) holding it in place. There is a bracket between the clamp and the frame rail.
Material I believe gets discussed frequently and I doubt there's very much more involved in choosing than "tossing a coin". For a strictly performance build yes but for everyday driving there's reasons to maybe NOT to choose what's considered premium. I'll leave material alone. Stock would be preferred I believe.
Old Oct 23, 2015 | 12:56 PM
JWASR64's Avatar
JWASR64
WVZR-1 Thank You for your information !
What is the sway bar size on the EF1, is it the 22mm ?
Old Oct 23, 2015 | 01:54 PM
WVZR-1's Avatar
WVZR-1
You haven't mentioned the year and I'd measure to be sure anyway if I were buying. It's maybe a "whose changed what" if the car has passed hands few times.
Old Oct 23, 2015 | 02:07 PM
JWASR64's Avatar
JWASR64
1995 auto coupe.
Old Oct 23, 2015 | 03:31 PM
WVZR-1's Avatar
WVZR-1
1995 auto coupe.
I believe for the front 26mm is mentioned most frequently. That's for a '95 and for the rear and FE1 I believe 24mm is expected. If you don't have a Vernier to confirm just wrap a string around it and measure the length of the string and using that as a circumference value calculate the diameter.
22mm never for a front and on the rear maybe '92 was last year.
To Sway bar link/bushing replacement
