Double Intake Gasket
Old Oct 30, 2015 | 07:13 PM
GotMe1's Avatar
GotMe1
Default Double Intake Gasket
I bought an 88 vert with a crate motor that was poorly installed. They couldn't get it running right. I have pulled the engine and tranny. I have noticed a double gasket on the intake. Intake is an eldebrock and the heads are supposed to be vortec mounted on a 355 roller crate engine. Any idea why the double intake gasket?
355 Roller crate engine
Old Oct 30, 2015 | 08:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by GotMe1
I have noticed a double gasket on the intake. Any idea why the double intake gasket?
Yes!
I'm guessing that base is a non-Vortec base. Since the Vortec intake ports are slightly higher than the non-vortec ports, you need to stack gaskets to raise the intake a bit, and get a seal. I've done it before when putting a CFI intake on a Vortec long block. Seems like hackery, but it worked just fine, in my case.
Old Oct 30, 2015 | 10:36 PM
BOOT77's Avatar
BOOT77
I used double thick(not stacked) Felpro gaskets for some vortex heads that were drilled for older style intakes.
Old Oct 31, 2015 | 03:03 AM
GotMe1's Avatar
GotMe1
I'll be tearing the engine down to spec it and make sure everything is good, mismatched parts seems a possibility. Some of the intake bolts weren't all the way in either.
Old Oct 31, 2015 | 04:29 AM
bjankuski's Avatar
bjankuski
If the heads, block, or manifold were milled excessively in the past this will cause intake to sit too low and you need thicker gaskets. Usually the gasket thickness is .060 but they make .120 thick gaskets to help wit this problem.
Old Oct 31, 2015 | 01:21 PM
mako41's Avatar
mako41
Here's another thread with a similar issue that might lead to potential problems, check it out;
https://www.corvetteforum.com/forums...nsumption.html
Old Oct 31, 2015 | 03:15 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is backwards. If you mill the heads, the intake sits to high on the heads. More gaskets isn't going to help that. In fact, the proper solution for that would be to mill the intake, as well.
Old Oct 31, 2015 | 09:00 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I was expecting to read the intake had been milled excessively but now i see the higher Vortec ports are the reason. Always learning something new w/sbc combinations - endless combinations.
Old Nov 1, 2015 | 02:25 AM
bjankuski's Avatar
bjankuski
You are correct, I should not have said heads or block, only the intake should have been in my comment. (Oops, typed answer without much thought)
Old Nov 1, 2015 | 02:39 AM
bjankuski's Avatar
bjankuski
Originally Posted by cardo0
I was expecting to read the intake had been milled excessively but now i see the higher Vortec ports are the reason. .
I am not sure why the higher vortec ports are the problem, that is a vortec intake manifold (You can tell by the flat machined bolt mounting pads on the end and the straight up bolts) and it was designed for the vortec heads. I would be leaning towards either the intake mounting surfaces on the intake have been milled too much or the end rails above the china wall on the intake have not been milled at all.(And you have a milled block or heads) If the end rails have not been milled the intake will bottom out on the china wall (I cannot tell from the picture) and be held up away from the head, requiring a thicker gasket. If this happens the ports and bolt holes for the intake will not line up very well.
Old Nov 1, 2015 | 07:18 AM
GotMe1's Avatar
GotMe1
Very interesting. This motor had the intake rocker backed completely off on one cylinder which was loaded with oil, actually dripping from header collector. It ran so badly, just like massive vacuum leak. Also, super rich as all the plugs were black .
Old Nov 1, 2015 | 07:20 AM
GotMe1's Avatar
GotMe1
I still have to take it apart, but seller claimed that it was a crate motor. Not sure if that means the heads came with it or not. I'm gonna have a lot of measuring to do...
Old Nov 1, 2015 | 12:00 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You are right. Good observation!
Old Nov 1, 2015 | 02:18 PM
cardo0's Avatar
cardo0
Ok so it was the intake then as added gaskets should only move the intake ports and bolt holes higher. Well isnt that the same thing as adding gaskets for aligning the intake ports? Well i guess not if your expecting to align just for an un-milled intake base. And an un-milled base should fit up to a un-milled block & heads. Well maybe for a vortec design base but not a standard GEN 0 base. In that case u need the gaskets to move the base ports (and maybe bolt holes) higher.
Something i think i can see from the pix is the heads - which look like vortecs - have a thick gasket rather than the usual thin (0.24"?) steel shim head gasket. Now this starts to make sense - at least to me. That motor could have vortec heads using a thicker composite gasket (over 0.040") raising the heads - which already have "raised" vortec ports. Now installing a GEN 0 TPI base with lower port locations means u need someway to raise the lower base ports. Ta Da extra intake gaskets! Well i bet the bolt holes on that intake are ground out and elongated too.
Whew! Thats enough. I think i have a headache.
Old Nov 2, 2015 | 08:00 PM
ex-x-fire's Avatar
ex-x-fire
Just beware of the oil pressure slot in the distributor can be miss aligned when the intake has stacked gaskets.
To Double Intake Gasket
