Harmonic balance help
Old Nov 4, 2015 | 06:03 PM
86couper's Avatar
86couper
Default Harmonic balance help
Hello to all,
I discovered my harmonic balancer to be flopping around on my 1986 stock engine. I removed the belt and the three bolts on the pully and thought it should come off easily. Not the case. I driven a tool in between the pully and HB a little ways and thought it should just pop off. Am I missing something? Just want to be sure. I haven't removed the crank bolt yet as this does not seem to be part of the equation from looking at things. I was also looking for a video or detailed step by step directions for an 86 to help me complete this project but haven't found anything yet. Any advice/help/rescue effort would be appreciated. Thank you!
Old Nov 4, 2015 | 06:53 PM
antfarmer2's Avatar
antfarmer2
do not take off the center bolt it will come off just a pita soak it withe pb blaster and keep hitting it or if it still runs put the three bolts in a leave a bit loose and start it a few times.
Old Nov 4, 2015 | 07:22 PM
ex-x-fire's Avatar
ex-x-fire
Use a steering wheel puller to remove it, its a press fit. You'll need an install tool too.
Old Nov 5, 2015 | 12:37 AM
Cliff Harris's Avatar
Cliff Harris
You DO need to remove the center bolt.
You need a puller. I used a Lisle 45500. I have an ancient Proto puller but it was too long to fit.
Old Nov 5, 2015 | 04:27 AM
bjankuski's Avatar
bjankuski
You need to pull the center bolt and use a harmonic balancer puller. It will take a lot of force to remove it.
Old Nov 5, 2015 | 07:57 AM
antfarmer2's Avatar
antfarmer2
looks like yous is differant from mine sorry for bad info. I went with my experiance.
Old Nov 5, 2015 | 11:56 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by 86couper
I removed the three bolts on the pully and thought it should come off easily. Not the case.
Originally Posted by Cliff Harris
You DO need to remove the center bolt. You need a puller.
I think that we as a group are a little confused here. The OP is talking about getting the crank pulley off. He's not yet to the Harmonic damper.
Don't need a puller to remove the pulley, typically. Should come right off w/bolts removed. You DO need to remove the center/crank bolt, however, for the pulley to come off of the damper.
Old Nov 5, 2015 | 12:01 PM
antfarmer2's Avatar
antfarmer2
thats how mine was per my instuctions but might be wrong not a lt1
Old Nov 5, 2015 | 01:16 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The OP's isn't an LT1 either; or is that what you were saying?
LT1, the damper IS the pulley. OP's looks like this:
^Older motor, but notice how the crank bolt washer overlaps the pulley.
Here is another pic...
Old Nov 5, 2015 | 01:42 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I removed the belt and the three bolts on the pulley and thought it should come off easily. Not the case. I have driven a tool in between the pulley and HB a little ways and thought it should just pop off. Am I missing something? Just want to be sure. I haven't removed the crank bolt yet as this does not seem to be part of the equation from looking at things.
We have an absolutely amazing number of opinions on this question!! Mr. 86couper, why wouldn't you try removing the crank center bolt? The pulley would have popped right off!
I did find an error in my '84 FSM, though. For reassembly, it says to install the center bolt before installing the pulley, but you quickly learn that won't work!!
Old Nov 5, 2015 | 01:43 PM
antfarmer2's Avatar
antfarmer2
yes that is what I was saying on my lt1 only had to take the 3 bolts out but still a pita.
with you helpful text and pics looks like he needs to pull the 3 bolts and the center bolt with no need to pull the hub to change the pully. learned something new thank you.
To Harmonic balance help
