Header & Torque Question
Old Aug 26, 2002 | 11:18 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Default Header & Torque Question
This is somewhat related to e streme's post where he said he lost torque after his header install.
Anyways, I remember reading a long while back that shorty headers make the most torque before the peak torque RPM, and long tube headers will improve torque in the upper RPM range, above the peak torque. Does that sound correct? or I am making this all up? :crazy:
Old Aug 26, 2002 | 11:30 PM
vader86's Avatar
vader86
Default Re: Header & Torque Question (X-FireChance)
yeah that sounds right
Old Aug 26, 2002 | 11:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Think about an organ pipe; the short tubes are high frequency and the long ones lower frequency.
Shorty headers, if involved in any tuning, are at high frequency; long tube headers would have tuning at lower frequencies along with higher frequency harmonics.
So, I believe long tube headers provide better low end torque as well as better high end scavenging.
Of course tubing diameter is also a factor in maintaining torque; note the discussions about which diameter is best for long tubes. As with intake tuning, exhaust velocity is an important factor.
If you care to do the math, there are references on this "header tuning" topic.
Old Aug 27, 2002 | 12:39 AM
Half Fast's Avatar
Half Fast
Default Re: Header & Torque Question (65Z01)
:yesnod:
Primary tube length can be used to tune the torque peak RPM range. Generally, the longer the primary tube the lower in the RPM range for the peak of the curve. Tubing diameter affects velocity and flow volume. More variables to consider. :cheers:
To Header & Torque Question
