I just made a panic stop and the pedal went to floor now I have very little resistance when I push brake pedal with or without vacuum booster.
No leakage and the reservoir is full. Is it the master cylinder?
Thanks.
Thanks.
I replaced the master cylinder and now have brakes.
I appreciate the comments from all of you.
Also the post regarding the brake indicator light staying on was helpful, just a matter of pulling the switch and moving the piston back a little so the switch plunger was in the correct position.
SEMPER Fi, Mike
