Carburetor secondaries not opening
Old Nov 18, 2015 | 05:26 PM
Charlieg0357's Avatar
Charlieg0357
Default Carburetor secondaries not opening
Hey folks,
I have an 86 Corvette carbureted motor(Holley 670) Today I realize the secondaries are not opening. It's so happens that the power break booster is bad and I know there is a vacuum line from the back of the carburetor to the brake booster. Could this be the problem? And a diaphragm feels fine.Thanks!
Old Nov 18, 2015 | 05:50 PM
Charlieg0357
Found a video that states that if you just rev the motor you shouldn't see the secondaries open that if you did they are likely opening too soon. Any way to check?
Old Nov 18, 2015 | 06:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I disagree w/the vid...if you hold the thing WOT, the secondaries should start opening (a little) before you hit your red line.
Other than that, you'd have to put it on a chassis dyno and watch the secondaries under a load.
Or put a Go Pro under the hood.
Or take the hood off.
Old Nov 18, 2015 | 06:39 PM
John A. Marker's Avatar
John A. Marker
If the secondaries are vacuum operated and not mechanical, then the brake booster vacuum could be the issue.
Old Nov 18, 2015 | 06:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^Not very well. The vacuum source for the 2ndaries on most if not all Holley carbs is the primaries. When the velocity becomes great enough through the primaries, the vacuum in/around the venturi becomes great enough to overcome the spring and pull the 2ndaries open. I don't think a manifold vacuum leak would have much impact on that, unless it was an enormous leak.
desertmike1's Avatar
desertmike1
I might be a little rusty, but doesn't the Vacuum come from the Primary [Venturi] And the more you open the throttle, there is an increase in flow across the venture, which in turn lowers the Vacuum at a drilled passage, which in turn moves the Secondary Dash pod even further.. and so on
I like the Go-pro idea.. but ya when you wrap the engine the secondary Butterfly should open some.
Old Nov 18, 2015 | 07:01 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey...look what I found:
How to test your secondaries
Old Nov 18, 2015 | 11:16 PM
Churchkey's Avatar
Churchkey
Change when the secondarys open with a diaphragm spring change.
http://www.summitracing.com/parts/hly-20-13/overview/
Old Nov 20, 2015 | 09:15 AM
project C4's Avatar
project C4
here is the cure for that . lol
Old Nov 25, 2015 | 03:00 PM
Mtn Billy's Avatar
Mtn Billy
Ummmm, double pumpers(drool)
Old Nov 26, 2015 | 02:07 AM
toobroketoretire's Avatar
toobroketoretire
Originally Posted by Charlieg0357
Hey folks,
If it has vacuum secondaries they'll never open by just gunning the engine in your driveway because the air velocity thru the primaries will never get high enough. To verify they are opening stick a bobby pin onto the top of the secondary lift rod (from the diaphragm) and take it out for a spin. If they are opening (and they probably are) the bobby pin will get shoved down lower on the rod.
Old Nov 26, 2015 | 10:33 PM
pcolt94's Avatar
pcolt94
A simple check and suggestion.
As said a lot of carburetors work on vacuum which comes from the manifold. On certain carburetors that vacuum comes thru the gasket on the bottom of the carburetor which there can be holes or passages that are parallel to the gasket. When the holes become clogged (from carbon) either in the gasket or hole at mating surface of the carb to the gasket, then the vacuum can't reach the carburetor to activate it's proper operation.
I would check the bottom surface to see if all is clean and aligned properly.
To Carburetor secondaries not opening
