My question is whether or not to install the bigger throttle body on my engine ? My modifications are as follows :
Edelbrock 3860 intake
SLP runners ported
Heads ported gasket matched
24lb injectors
Adjustable fuel pressure regulator set at 40.
Long tube headers
Dual exhaust 2.5"
High flow cats Flowmaster 44 mufflers
You can go bigger, but there will not be a gain. It is not like going from a 2 barrel carb to a 4. The TB you have on there now will support 400 HP without a problem and you are no where near that currently.
Just thinking over this myself the other day. 1st you can't compare a carb to efi, carbs depend upon signal for atomization and a injector does that job very well(maybe not so much in a batch fire setup like TPI). 2nd the NA engine can only draw what it can use and to say what it can use varies widely, mods, use, tune skill. IE look at all the basic TB efi kits like msd/holley, they are 1000cfm or bigger and some rated for like 200hp-600hp, so efi is more forgiving for oversize. Still that doesn't mean you want the biggest TB, because the faster it reaches what it can use in throttle position the less sensitive your throttle is.
I think for TPI it's a lot about if your MAF or SD. MAF obviously the restriction is if your using stock stuff(MAF,duct,airbox) and SD you can just use a big air filter on the TB. My car is a MAF car so unless I want to change all my stuff or convert to SD I'll stick with the stock TB for now.
edit: Oh and I also think size can effect your curve for the better and still have the same peak.
I'm running a 383 with the high flow Accel intake, the same 3860 manifold, the same 24 lb injectors and a set of Dart pro 1 (180) heads , long tube headers ,and the 48 mm throttle body does just fine on my engine....WW
This answers my question best. I wish now I had stroked my L98. I have considered putting AFR heads on it to boost the HP but even then my stock throttle body would provide adequate air flow. I do have a open lid with a fresh K&N filter. I've never had it on a dyno so I don't know what my HP is now. I test drove a stock 1988 C4 and was thinking this is slower than new Fiat 500. She's a tire screamer now and grabs tire shifting at 2nd and D. A loud chirp on stock tires. I saw a ported to 52mm throttle body for cheap and considered buying it. It won't so end of story.
I got mine as part of the set and decided to keep things the way they were. A buddy put a 58mm one on a stock vette and did back to back trials. Felt faster but went slower. My system is set up to run it but if I had to buy it for a stock Vette, NFW now that I am wiser but poorer. If only I knew then what I know now.
Notice the ads say "Up to 20HP gain". What they don't say is that you might lose power all the way to gain 20HP but the 20HP gain is going to be part of a system that NEEDS the air flow.
Never liked dyno numbers w/o curve results or averages, also not enough details on his car really. Still even then real track results are only what matters.
Well, that is more objective data than you posted. Bottom line; if the TB doesn't make HP at the HP peak where air flow into the engine is greatest, then how is it going to make power anywhere else, where air flow is lower?? What do you think you'd see w/a curve?
I supercharged my 86 with the stock throttle body and did fine. I had more issues with the airfilter than anything. That thing would eat a stock filter and I could actually tell when the k&n needed cleaning performance wise. Only vehicle Ive ever owned that actually needed a k&n over the stock filter
My 87 is a 383 stroker with the stock throttle body and does great.
It is ambiguous when people use words like "can", works", etc. What would be better to know is whether it shows gains with the large TB or not. With the stock engine, I had a friend who ran it with and stock, back to back. It ran slower with the large TB.
OTOH, I was getting it dyno tuned and we ran with the cut out air cleaner and I without anything and got more power bare and lost like 4, IIRC, with cut out intake. Lost 1 or 2 with K&n open element which is why my stock cut out intake filter went to be recycled
