Replacing rear pads question
Old Dec 2, 2015 | 07:09 PM
Ron B C4's Avatar
Ron B C4
Default Replacing rear pads question
Replacing the rear pads on my 95. I have the piston compressed. The rear disc I have done before you had to rent a tool to turn in the parking brake. These don't seem to work the same way.
Am I missing something? Or do I just compress piston and good to go?
I haven't tried to install them yet. Gust getting them ready and cleaned up so I can paint. Just don't want to have to mess with them a lot with fresh paint on them.
Old Dec 3, 2015 | 04:13 AM
Christi@n's Avatar
Christi@n
You had to remove brake fluid reservoir cap and push Using piston tool or even gently using a pipe whrench with a tovel, in order to avoide any damage on caliper body and piston.
Old Dec 3, 2015 | 04:15 AM
Christi@n's Avatar
Christi@n
What do you ecxatly mean?
Old Dec 3, 2015 | 05:08 AM
WW7's Avatar
WW7
The screw in pistons weren't around back then, just compress and install the pads...WW
Old Dec 3, 2015 | 08:26 AM
csthews's Avatar
csthews
I bought the cheap brake compression tool from Harbor Freight. It kinda worked, but was a bit tedious. In the end, I went back to the old school C-clamp method.
Old Dec 3, 2015 | 08:49 AM
antfarmer2's Avatar
antfarmer2
I always open the bleeder to compress with a vacumme bleeder do not want to backfeed crap in the system. then vacumme bleed fresh fluid in. harbor frieght has the vacumme tool.
Old Dec 3, 2015 | 04:47 PM
Ron B C4's Avatar
Ron B C4
Thanks for the replies. WW7 hit it on the head. Their was never a problem compressing the piston.
To Replacing rear pads question
