Flashing SYS light
Old Dec 19, 2015 | 06:18 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Flashing SYS light
What are the causes of this. The electrical system is stock it only does it when it's cold out side. Charging system is working according to the dash.
Old Dec 19, 2015 | 06:22 PM
antfarmer2's Avatar
antfarmer2
might just be a weak battery saying good bye
Old Dec 19, 2015 | 06:29 PM
Nowhere Man
That's what I thought I think the battery is 6-7 years old.
Old Dec 19, 2015 | 07:02 PM
DUB's Avatar
DUB
You have a trouble code that is stored in your BCM or CCM and it is NOT the same as your CHECK ENGINE LIGHT
GO down and read what '93WhiteTexas' wrote
http://forums.superchevy.com/corvett...light-on-1993/
DUB
Old Dec 19, 2015 | 07:06 PM
Nowhere Man
Wonderfull.
Old Dec 19, 2015 | 07:25 PM
Silver96ce's Avatar
Silver96ce
From page 82 of the 1994 owners manual -
System Problems
If “SYS” flashes on the display near your fuel gauge, there may be a problem with your Corvette’s electrical system. If the “SECURITY” light flashes at the same time, there is a problem with your theft deterrent system. Have your vehicle checked by your dealer if “SYS’ keeps appearing.
Here's a link to the owners manual in .pdf form.
http://justgivemethedamnmanual.com/c...-owners-manual
Old Dec 19, 2015 | 09:51 PM
jframe's Avatar
jframe
The one in my 94 has been flashing since I bought it in August. I can't see where it makes a damn bit of difference in running or anything else. I did see where some folks claim they will flash with aftermarket radios because of the lighting in the radios. May be true; I have a JVC deck, so it could apply.
Old Dec 19, 2015 | 09:56 PM
Silver96ce's Avatar
Silver96ce
Yeah an aftermarket stereo can do it but usually it's the battery or the battery connections have corrosion.
Old Dec 20, 2015 | 08:56 AM
WVZR-1's Avatar
WVZR-1
System Problems
You can source any available GM owners information including the Owners Manual from this GM link and you don't need to establish an account. I believe that the Owners Manual is only available for '93+ models.
https://my.gm.com/home
Old Dec 20, 2015 | 09:06 AM
Nowhere Man
thanks every one. I do have a owners manual.
Old Dec 20, 2015 | 09:49 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
That is the number one cause of the flashing SYS, especially if it is something new.
An aftermarket audio system can also cause the flashing SYS
There used to be a link in the audio section regarding a TPS on fixing this issue, but the link no longer works.
With the righ
Old Dec 20, 2015 | 09:53 AM
Nowhere Man
When I first bought the car it had a aftermarket radio and the light did flash. When I put the stock radio back in the car it went off. And that's the last time I remember it flashing. Like I said the battery is 6-7 years old. And it only does it when it's cold (40* below). So I guess all signs point to dying battery.
Old Dec 20, 2015 | 09:57 AM
WVZR-1's Avatar
WVZR-1
Time for at least a "load test" I'd think and maybe just an evaluation of the entire charging system. Replacing a battery with a failing charging system wouldn't be wise.
Old Dec 20, 2015 | 10:04 AM
Nowhere Man
The gauge in the dash is reading normal both analog and digital
Old Dec 20, 2015 | 11:08 AM
WVZR-1's Avatar
WVZR-1
I get that but that's not really a very accurate or efficient (poor word choice maybe) evaluation of the system. A "for hire" load test of the entire electrical might point you towards a less than ideal alternator charging rate, a poor battery which you suspect which would really strain a good alternator likely to a "failure" of it.
A carry in "load test" of just the battery after it's been charged appropriately is for sure a required "next". A battery removed from the car and just carried in isn't ready for an appropriate "load test".
Old Dec 20, 2015 | 11:19 AM
Nowhere Man
Just got back from the auto parts store. Where they did a load test on the charging system. The alt came back fine and normal. The battery came out as low. As well the car has a slugish start up. So I did but there better battery. Will be installing shortly.
Old Dec 20, 2015 | 12:00 PM
Nowhere Man
Just got done with installing battery and the flashing light went off and it starts right up
To Flashing SYS light
Old Dec 20, 2015 | 12:05 PM
WVZR-1's Avatar
WVZR-1
Sounds like it was relatively "painless" - well maybe the wallet a little but done. Have the AP store do their load test again maybe after putting some miles on it and allowing the battery to maybe arrive to an appropriate charge.
Old Dec 20, 2015 | 12:23 PM
Nowhere Man
Yeah only 120 bucks painless. But a new battery solved the problem. Better to change it before it leaves me stranded somewhere
Old Dec 20, 2015 | 01:25 PM
antfarmer2's Avatar
antfarmer2
good job I hope you cleaned the connection block behind it.
