Over fueling problem
Old Dec 23, 2015 | 04:52 PM
HarleysVette's Avatar
HarleysVette
8th Gear
Default Over fueling problem
1985 C4 Corvette 350 5.7 TPI (Completely stock)
Car is throwing a code 43 for the ESC module...
It is over fueling really bad, black smoke coming from the exhaust pipes and has created two black mud puddles on my garage wall from unburnt fuel spewing out.
My mechanic says the timing chain has slipped and that the valves are not opening at the correct time, all of this started happening after i took the valve covers off...
Items already replaced;
Spark plugs
spark plug wires
fuel pump
fuel filter
distributor cap
distributor rotor
ECM
I just want to know what you guys think about what my mechanic is saying....
I have another friend that is telling my i bumped something when doing the valve cover gaskets, and he thinks my timing chain is just fine....
Old Dec 23, 2015 | 05:06 PM
Mishawaka's Avatar
Mishawaka
Spark plugs
spark plug wires
fuel pump
fuel filter
distributor cap
distributor rotor
ECM
I would have to agree with your friend. Check the basics and look over everything you did.
Old Dec 23, 2015 | 05:18 PM
antfarmer2's Avatar
antfarmer2
I would look at you fuel pressure regulater diaphram and vacumme line
Old Dec 23, 2015 | 05:27 PM
aklim's Avatar
aklim
ARE YOU SURE that you put all the hoses and connectors back where they should be? If so, fine. CHECK AGAIN. Make sure you haven't forgotten to connect back something and/or have a loose hose. Hook up scanner. Does it show anything for MAF? I don't have MAF so I can't tell you what you should see but someone should know. Also, I would take the valve covers off again and see if you have a rocker loose or something just to be safe.
If you can see what the ambient air temp and coolant temp is and that the MAF is changing when you hit the gas, you might have something. I forgot what my pulse width is when it was stock so that might be a clue. Could your injectors not be hooked up on the driver side hence making the ECM think that the car is running lean and thus dumps fuel? I had that years ago and the O2 sensor reading was very lean and the ECM tried to dump fuel into the car
Old Dec 23, 2015 | 09:25 PM
touyech2883's Avatar
touyech2883
I wanna say that esc is electronic spark control and I believe there is an ignition control module under your distributor cap also under the rotor, looks like it's part of the base of the distributor with wires going to it. You can see it if you pull the distributor cap. This is important for timing the injectors and ignition and can go bad or maybe you disturbed some wires under there when you removed the cap. I've also seen he little wires to the in module get corrodid and break. Seeing as how it's basically throwing a code for that part it check that first, heck replace it anyways its a pretty cheap part.
Old Dec 23, 2015 | 11:35 PM
Cliff Harris's Avatar
Cliff Harris
There are two ways to get an error code 43. Too bad GM didn't separate them with different numbers, but it is what it is.
When you start the engine the ECM adds an extra 20° of advance. That causes knocks. The ECM looks for at least two knocks and then resets the spark advance back to normal. If it does NOT see at least two knocks it sets error code 43. This checks that the ESC module is functioning correctly.
When the engine is running the ECM will set error code 43 if it sees less than 6 volts from the ESC module. Normally it's about 7 volts or slightly more.
This ECM waveform shows the two knocks at startup and the steady 7-8 volts after that:
Basically, what all this is telling you is that your ESC module (or the wiring associated with it) is bad. You might have a problem with the knock sensor (or its wiring/connector)
Old Dec 24, 2015 | 12:17 AM
aklim's Avatar
aklim
I agree with what you said but what exactly did he do? He fiddled with the top area so wouldn't you think it is more likely, and thus we should look up top first before going down?
Old Dec 24, 2015 | 12:23 AM
HarleysVette
8th Gear
My question is, would anything with this ESC have to do with the overfueling problem?
Old Dec 24, 2015 | 12:31 AM
aklim's Avatar
aklim
I suppose you can check the wiring and make sure that it is attached. I'm not sure but maybe a crazy stupid idea is that it is reducing advance so much it doesn't ignite properly? Crazy enough that I would think I am crazy for thinking of it. Have you seen what the scanner says? Have you cleared the code and see if it comes back? I had a problem with an OBD 2 car with P0133. All things pointed to the front O2 sensor. Swapped MAF, plugs, wires, injectors, after we replaced the front O2 sensor. Nothing worked. Rear O2 sensor was supposed to be monitoring the efficiency of the cat converter. CEL came back every time after 20 mins or so of driving. As a "Hail Mary", we changed the rear O2 sensor. Never came back. Swapped it back, it came back, swapped to new and it was fine again.
Old Dec 24, 2015 | 12:40 AM
aklim's Avatar
aklim
I forgot the codes I was getting but I pinched the wire on the injector harness doing the valve covers eons ago. Injector bank shorted out and stopped firing. Car ran pig rich and we noticed the huge jump in pulse width. Fixed wire and car ran right again. You were playing with the harness. Maybe a pinched wire? Check with scanner.
Old Dec 24, 2015 | 05:05 AM
kenmohr's Avatar
kenmohr
My 89 had the same miss and puddles and it was the fuel regulator
Old Dec 24, 2015 | 09:56 AM
aklim's Avatar
aklim
It's possible but why does that happen? All he did was pull the valve covers. How did it affect the FPR? Kinda why we should check what the scanner says as to whether there is an air leak, injector pulse width massively changed, etc. It could be the FPR and he should verify that with a gauge. I also think he should check the timing in case he bumped the thing.
Old Dec 24, 2015 | 10:08 AM
kenmohr's Avatar
kenmohr
I just shut mine off at a car show (running perfect) an started it to leave and and bearly got home.
Old Dec 24, 2015 | 10:33 AM
antfarmer2's Avatar
antfarmer2
it can go anytime put a gauge on it and see if it holds pressure.
Old Dec 24, 2015 | 11:10 AM
aklim's Avatar
aklim
Yes but you didn't muck with the car. He has made moves on the upper end so that is where he should start, right after scanner does it's work.
Old Dec 24, 2015 | 04:53 PM
HarleysVette
8th Gear
what kind of scanner do i need to use? what should i be looking for?
HarleysVette
8th Gear
Just an OBD1? or something else?
To Over fueling problem
Old Dec 24, 2015 | 05:12 PM
aklim's Avatar
aklim
At the very least. Maybe a Snap On "Brick"? If you like, get something that reads BOTH the OBD1 and OBD2. That way you have something that can do your other cars
Old Dec 24, 2015 | 05:13 PM
aklim's Avatar
aklim
I have an older Auto X-ray 6000, IIRC and a "Brick" and the software for my laptop which has cables to plug into the ALDL.
Old Dec 24, 2015 | 11:05 PM
HarleysVette
8th Gear
so are there any checkers available for an obd 1 system that will pin point the broken connection exactly?
