94 - Doing Valve Cover Gaskets
Do I have to remove the rubber hose from the pipe (drain some coolant) before I am able to get the valve cover off? I tend not to force the cover past the pipe in fear of breaking the metal pipe at this time. If I take the hose off the pipe, will it clear? (still looks close).
(I just cant believe its designed like this).
I did not even know that stud came out till I saw the far right one where I had some visibility since I had the cover on an angle.
Then it was cleaning every piece and putting all the new gaskets on. Put coolant back in and ran to temp so it could cool down and suck from the overflow tank the coolant it needed.
So right side is complete and starting on the left side. Lots of stuff to take apart but it's just a bunch of bolts but at least I can see exactly what has to be done. I think this is going to be easier.
Not much feedback on my thread. I guess not many have been down this road.
So here is a few things to know if you should do this job. (New pictures, deleted photobucked)
This stud can be removed with an allen head driver and removed before cover is removed. It will give you additional clearance.
Good picture of the pipe over the cover.
You can see the water pipe on the left that would be over the valve cover. I removed the hose which was necessary and gave much additional clearance. But the pipe still scrapped along the cover removing it and putting it back on.
This is one of the two studs that the plastic cover snaps on to. It just unscrews which releases the hold down for the wire bunch. The wires need to move to get the cover off.
There is some clearance from the pipe but you do have to lift the cover some distance to clear the rockers. The side of the cover could not get over the rockers and stuff.
It is an automatic. I don’t know what stud you are refereeing to as I called out 2 studs in 2 separate pictures.
Nest time I look at another C4 I will look closer to see any differences.
A reproduction pipe here:
http://www.ebay.ca/itm/1992-1994-C4-...item280174f9ea
https://www.google.com/search?q=1992...nSpuu8t-hEM%3A
I also looked for pictures on the internet, first Haynes book and FSM I have but really never found a picture with any good angles that you could really see.
So maybe a next car show I could see several cars at one time and see what's what.
Going to finish the left side today, just want to do some additional cleaning while things are more open.
