oil pressure
Old Dec 25, 2015 | 10:50 PM
jkann1's Avatar
jkann1
Default oil pressure
I have a 1984 c4 I been playing with.. put a 1986 instrument gages in the 84 plug rite in no problem.. notice the oil pressure reading is between 55/60 psi.. when it get hot really no change it drops a little 45/50 not much is that normal or bad reading on the 86 gage.. what is the normal reading... Thanks for your time
Old Dec 25, 2015 | 11:06 PM
WVZR-1's Avatar
WVZR-1
Good to see that the cluster actually did work for you.
You'll need to confirm the oil pressure to know if the dash cluster is reporting appropriate pressures. A mechanical gauge maybe for confirmation OR maybe just measuring the OPS output from the sender using a DMM. These are RESISTANCE values applied to cluster to confirm the gauge but similar results should be seen from OPS to confirm possible operation.
