fix airbag light
Old Dec 26, 2015 | 09:43 AM
JANO's Avatar
JANO
Default fix airbag light
Hi to all
-just vant to fix air bag light after repair ground on airb. sensor... zr1 94-
have 16 pin connector , which one is K to ground it? Clear code procedure is same like on the older cars ?
-done ground with 4th lower pin from left and got on dislpay c12 (1) and H64(9) what is that mean ?
tnx for replies ,Jano
Old Dec 26, 2015 | 11:25 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by JANO
Hi to all
See this thread and I believe you'll understand what's needed.
https://www.corvetteforum.com/forums...post1551454672
In your FSM see pages 8D-8 & 9. The entire 8D- section is CCM related and diagnostics using the DIC function buttons.
Good Luck!!
