Quality Control Not
Old Dec 29, 2015 | 10:24 PM
Zpeedstr's Avatar
Zpeedstr
Default Quality Control Not
Seems like either nothing fits, or it fails, or it's wrong; making repairs to my '96 C4 LT4 a challenge.
Just replaced clutch, & flywheel.
On startup the whole car vibrated and 2,000 rpm was impossible.
Inspection showed that the new Fidanza aluminum flywheel was missing the counter weight. Called Fidanza, and they said it should not have left the factory without the weight. They shipped the weight, but still waiting.
Previously the twin disk Ram clutch disk failed. The splines on the disk were not hardened and stripped, which destroyed the splines on the trans input shaft. Thanks ZFDoc for a new trans. But no thanks to Ram, and no refund.
Old Dec 29, 2015 | 10:31 PM
THE 383 admiral's Avatar
THE 383 admiral
Sorry, for the terrible luck!! I have learned from Many vendors. Inspect, measure. everything. This type of Quality Happens ALOT!!
Old Dec 29, 2015 | 10:48 PM
pcolt94's Avatar
pcolt94
It is a disgrace today of what you indicated. Hard to find quality as many after marked manufactures just want faster, cheaper, better. But seems like it's only cheaply made. I have gone thru similar situations, lots of lost time doing it 2 or 3 times.
Old Dec 30, 2015 | 05:45 AM
blackozvet's Avatar
blackozvet
there are certain jobs you dont want to do a second time, clutches and gearbox's are definitely one of them !!
Old Dec 30, 2015 | 11:02 PM
383vett's Avatar
383vett
It's a conspiracy against you. All the clutch manufactures have seen your name on the list.
To Quality Control Not
