I run a 15X10 wheel with 6.5 BS and fits a 28X10.5 or 275/60R15 Radial under it perfectly. No spacers or anything.
Will
I only plan to run a 28x10.5, but I have a few friends running very fast in the 235 class and the 8.5 class...they run 10" wheels with 8.5" tires..do you think a 12" wheel would fit with a 10.5" tire?
The suggested rim with for a 28x10 MT/ET drag tire is 10". Why would you want to go with a wider wheel? I believe Will (rcklessdriver) is in the 8's with his 10" wheel setup.
A buddy of mine, bobby kruck, just went 4.41 in the 1/8th on a 235 radial running a 10" wheel. It's something many of the pro street and big class guys do.
On mine the 28x10.5 slick will just rub the inner fender in turns. A 12" wheel could help with that because it wouldn't bulge the sidewall as much.
I'm sure it work but I just don't know about the BS on a 12" wheel to make it fit proper.
I'm going to be running a 275 radial this season but the 28x10.5 has been good to me over the yrs.
Will
Yeah that's something I would leave to asking the wheel manufacturer. They would be able to set me up with the proper wheel. I would likely run a radial aswell. Our local track isn't a sandbox like many others. Low 7 second passes have been made in street cars on a 275 radial.
