Which afr heads
Old Jan 17, 2016 | 08:55 AM
kitttransam's Avatar
kitttransam
Default Which afr heads
I'm planning on buying a set of afr heads and I am contemplating on whether I should get the ones with 65cc or 75cc chambers. I have flat top Pistons in my engine and thinking I have too much compression since I get a lot pre detonation when the temp is running around 200+ degrees.
Old Jan 17, 2016 | 09:00 AM
kitttransam
Forgot to mention it's an 89 corvette. With the 58cc l98 heads.
Old Jan 17, 2016 | 10:43 AM
STH's Avatar
STH
I'm guessing you have a stock L98 motor. If you are having pre-detonation at 200 degrees the problem is elsewhere than your current compression ratio. I'm running AFR-195's cut down to 60cc on my 90 Vette with a 383 in the middle-east, with no detonation problems. Start looking at your timing, see if you can pull any codes from the ECU. Good Luck.
Old Jan 17, 2016 | 11:06 AM
DanielRicany's Avatar
DanielRicany
Are you hearing pinging or knocking? Could you be hearing an exhaust leak or engine knock?
Old Jan 17, 2016 | 11:13 AM
kitttransam
My motor isn't completely stock. I rebuilt it when I bought the car. Original motor had dished Pistons. I put in flat tops. I also put in a zz4 cam. And I had a custom chip put in for my engine specs. I also have the Bosch 3 injectors. I have my ign timing set at 6. I've tried 4 but same thing still happens. I've e replaced the egr valve also thinking that was it. But it wasn't.
Old Jan 17, 2016 | 12:04 PM
kitttransam
If I remember the engine kit I got from summit came with a high volume oil pump. Could that cause any issues related to pinging knocking??
Old Jan 17, 2016 | 12:06 PM
kitttransam
It's definitely more like pinging and running bad. Only at running temp though.
Old Jan 17, 2016 | 12:22 PM
DanielRicany
Try retarding the timing to 0 and put some octane booster in your tank if you are already using premium.
If it goes away, it can be fixed in your tune, if not, then you have a mechanical engine issue.
Old Jan 17, 2016 | 12:54 PM
aklim's Avatar
aklim
How did you determine it was pinging? Did you check the ECM for knock? What about fuel pressure? Oil pump should not cause knocking issues. When did you get the Bosch 3 injectors? Have they been checked? Have you checked the fuel pressure regulator for holding pressure? What about WOT pressure? Does it drop off? Maybe your custom chip is off?
Also timing. How do you know that the timing is right? Could your harmonic balancer be walking on you? I would check timing again and if it is 6 still, put a white stripe on the balancer and run for a bit. If it moves, toss the balancer. That could affect your timing so you might THINK you are at 6 when you are at 20.
Also who wrote the custom chip?
Old Jan 17, 2016 | 01:03 PM
kitttransam
I have checked the fuel pressure. Tried adjusting it and still same results. Fuel pressure holds at wot. I replaced my balancer also thinking the same thing maybe slipped but that didn't solve anything either. I've hooked up and auto X-ray and drove it. And it is reading a lot of knock counts. I've done most of the checking and poking around the last couple years when time was available.
Old Jan 17, 2016 | 01:04 PM
kitttransam
I bought the Bosch 3s back in 2009 from fuel injector connection. Scott hansen wrote my chip
Old Jan 17, 2016 | 01:06 PM
aklim's Avatar
aklim
Assuming you did it all right, who wrote the chip? If it is some fly by night operation, they might have gotten it wrong. I wouldn't just throw parts at it anymore. Give my tuner a call. Worst case you throw away $275 at a chip.
http://hitechmotorsport.com/index.ph...art&Itemid=274
Old Jan 17, 2016 | 01:08 PM
aklim's Avatar
aklim
09 is a while ago. I'd send it back for testing and cleaning. I do it myself every 3 years or so. Could be that varnish has clogged up the injectors. Hard to say. Every time I send it in, I get a more balanced set and I have tried different vendors and same results. They get some gunk every so often. I don't use snake oils to imagine them being cleaned.
Have you talked to Scott and see if he can datalog and give you some idea of what is going on?
Old Jan 17, 2016 | 01:30 PM
kitttransam
I'll see about talking to Scott about doing that. Sounds like a good idea.
Heck the car does run great. But let's just say I was going to take a 60 mile trip somewhere on a hot day. By 50 miles on the freeway I start getting problems. Then I get into town cars running hot like every c4 does. Pinging and the whole works. I shouldn't have any cooling problems have a Dewitt's radiator.
Old Jan 17, 2016 | 03:39 PM
bjankuski's Avatar
bjankuski
You should get the 64cc heads, the 64 cc head will drop your compression by .75 of a point. Depending on what you have for parts the compression you have with the 58 cc heads is 10.9 and the 64cc heads will be 10.15. The 75 cc head will yield 9.0 to 1. You need to work on your temperature, you should not run a high compression, high performance sbc above 200 degrees. Program the chip to turn the fans on at 200 and off at 196. Also check you squish clearance it needs to be around .040 to be effective. Once these issues are addressed you will not have problems.
Old Jan 17, 2016 | 07:25 PM
kitttransam
I think this answer is sounding legit. Even my dad that is a retired auto tech. Told me the same thing. Higher compression could cause problems. That's why I was thinking of getting the heads in the first place.my chip is programmed to come on sooner than stock. I want to say 210.
Old Jan 17, 2016 | 07:45 PM
aklim's Avatar
aklim
Ask him how you can datalog and sent it to him for his analysis. Without datalogs we can guess all day long but since he set up the program, maybe he can see where it went sideways? I got someone to do a diacom reading when I took a snapshot when the car misbehaved a long time ago and it came out that it was a program error. He fixed it and life was good.
I'd be curious as to why it does what it does since the car should reach open loop way before 50 miles. In summer, within 10 minutes, it should be at a stable operating temp which mine does. What temp does the ECM see at that point?
A WAG is that maybe you have a sensor that gives bad feedback because the engine area is hot enough and the metals expanded enough to cause a gap and change resistance? Just a WAG.
To Which afr heads
Old Jan 17, 2016 | 07:47 PM
kitttransam
Yeah I have to buy a cable and fix the laptop I have before I can datalog. But I talked to Scott. All I have to do is do it and email it to him.
Old Jan 17, 2016 | 07:53 PM
aklim's Avatar
aklim
But what is the engine temp at that point? My guess is that if the compression is too high, it should cause problems all over and not just after that long a while. Is the problem only in open loop? Doesn't sound like it. Maybe something about the program in closed loop?
Old Jan 17, 2016 | 07:55 PM
kitttransam
The problem is when I'm running 200+ degrees.
