1987 Vette: Will not start.
Old Aug 30, 2002 | 05:12 PM
psukid13's Avatar
psukid13
5th Gear
Default 1987 Vette: Will not start.
I have a 1987 Vette and recently the car has not been starting. When i put in the key the turn, all the lights come on but you can't even hear the engine. I've looked around online and heard things from the chip on the key is worn out or it's something with the VAT system. I know this problem is out here and hear it all the time but can't seem to get down to exactly what is causing this. Does anyone know? Thanks.
Old Aug 30, 2002 | 05:16 PM
ZylaRace's Avatar
ZylaRace
Default Re: 1987 Vette: Will not start. (psukid13)
If it is VATS, you will need to replace the lock cylinder. The contacts in the cylinder wear down and don't contact the key-chip.
I have very good success by inserting the key, then giving it a jiggle before the twist. If it doesn't work,.... you get to sit and wait.
If it does start,.... a new key/chip may by you some time, till you get a new cylinder.
Old Aug 30, 2002 | 05:18 PM
psukid13's Avatar
psukid13
5th Gear
Default Re: 1987 Vette: Will not start. (ZylaRace)
What? a new cylinder? how much do they go for? I ask cause i only have about 14K on my 87 vette. :mad
Old Aug 30, 2002 | 05:20 PM
scorp508's Avatar
scorp508
Ok first.... what does your security light do when you are trying to start the car? Is it on? Is it blinking? Is it off?
Do you hear any rapid clicking at all or just silence?
Old Aug 30, 2002 | 09:11 PM
psukid13's Avatar
psukid13
5th Gear
Default Re: (scorp508)
i don't recall if the light is still blinking though i do know that there is no clicking noises.
Is this start up issue a common problem with vettes?
Old Aug 30, 2002 | 09:19 PM
paintdaddy's Avatar
paintdaddy
I dont know what kind of trans you got but I had this same problem a few years back.and it ended up being the clutch safety switch .
Old Aug 30, 2002 | 09:34 PM
psukid13's Avatar
psukid13
5th Gear
Default Re: 1987 Vette: Will not start. (paintdaddy)
I have an automatic. So it wouldn't be the clutch, right?
Old Aug 30, 2002 | 09:43 PM
Maximus9000's Avatar
Maximus9000
With an automatic the clutch switch wouldn't be it. I too have an 87 and when I went to pick it up at the body shop a few months back it did the same thing. Everything seemed fine, except the engine wouldn't crank, no clicking, nothing. This guy there comes out with a jumper box and say let's give this a try. We hook it up to the battery and it fired right up. I don't know what the deal was but it worked. Try and jump start it and see what happens, maybe you'll get lucky. :confused:
Old Aug 30, 2002 | 09:44 PM
Caboboy's Avatar
Caboboy
right, but you have a neutral start switch, same thing. Sounds like vats to me though. Have you been able to get it started at all? I had to replace my lock cylinder a few years ago, I had the same symptoms. What a drag it was :mad .
If I had to do that one over again, I would work some overtime and just take it in and write a check instead :lol:
Old Aug 30, 2002 | 09:52 PM
psukid13's Avatar
psukid13
5th Gear
Default Re: 1987 Vette: Will not start. (Maximus9000)
but if it was the battery then why are all of my dashboard lights lit perfectly and my headlights can work??? :confused:
I can start it the majority of the time. But sometimes, when it doesn't start, i have to wait for like 10-15 minutes b4 it'll start again. Does this mean that the security system takes that long to reset itself???
Old Aug 30, 2002 | 10:04 PM
paintdaddy's Avatar
paintdaddy
Maybe it is your nuetral safety switch.It is on your shifter and tells ypour ca that it is in nuetral or park and it is ok to start.
Old Aug 30, 2002 | 10:31 PM
jfb's Avatar
jfb
If you at least don't hear the start enable relay click behind the center of the dash, then it sounds like VATS preventing a start. Find the two pin connector under the carpet on the floor by the steering column. This brings the ign sw contacts that make with the pellet over to the VATS module. Unplug and with the key in, measure the resistance of the wires from the steering column. The resistance should be the same as the pellet. If over 10k ohms, you need a new ign sw. You can temporarily defeat VATS until you can get the new ign sw by clipping a fixed resistor the same value as your pellet on the two wires going to the passenger side . This will make VATS believe the correct ign key is in the sw. You can also jump the xmsn selector sw to prove that it is not that.
Old Aug 30, 2002 | 10:34 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Check the connections to the battery also. They can get loose or corroded over time.
Old Sep 1, 2002 | 12:30 PM
dlmeyers's Avatar
dlmeyers
Default Re: 1987 Vette: Will not start. (AquaMetallic94LT1)
Check your codes. There are some conditions that will set a VATS code and your headed in the right direction. Sounds like VATS to me. Check to see if there are any service bulletins associated with 87. Believe there is one about the cylinder locks. Eventually, the good ole mulitmeter point check will be required.
dlmeyers 90 coupe zf6 3 speed shocks
Old Sep 1, 2002 | 12:40 PM
scorp508's Avatar
scorp508
Did it start yet?
Usually if VATS gets ya' you have to wait 10 minutes before trying again. For peace of mind clean the resistor contacts on your key (it isn't a computer chip, mearly a resistor) with some rubbing alcohol.
Old Jun 21, 2023 | 01:26 PM
Erna's Avatar
Erna
3rd Gear
its the bats system. will let it start later. only fix is bypass the system..YouTube vids out for this procedure
Old Jun 21, 2023 | 01:28 PM
Erna's Avatar
Erna
3rd Gear
vats system can be bypassed to stop this annoyance
Old Jun 21, 2023 | 06:59 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
21 years later, .
To 1987 Vette: Will not start.
