engine build question
Old Jan 24, 2016 | 11:23 PM
aklim's Avatar
aklim
Originally Posted by THE 383 admiral
This is good to know. Why else would most owners want 400-500hp. You typically are going to bring the car to the strip.
Of course if you drove the car around like a parade car. You would not break parts.
I do a couple of WOTs at least each day it goes out on the street.
Old Jan 25, 2016 | 05:40 AM
drag racer 9's Avatar
drag racer 9
Originally Posted by 94VenomVette
What about pushrods & lifters? Would like to start fresh on them as well obviously
All the guys are making good points. One thing I can tell you is if you make one change you have to make others. Also watch your clearances. I'm sure the guys will agree with me. If your tearing down the motor change the bearings and freeze out plugs. Now if you see what I'm getting 2 it gets very expensive very fast. You need to know what your doing and have a game plan. My Race motor I have a lot of money just in the bottom end alone. If your making all the changes your thinking about remember this if your building compression your not going to run on pump gas. The motor will knock and ping. I'm not trying to put you down. Maybe just trying to get you to think about. But a good race motor really sounds good. Good luck Buddy
Old Jan 25, 2016 | 06:05 AM
aklim's Avatar
aklim
If I buy a $200 junkyard motor, I have no issues honing, rings, gaskets, bearings and small misc items to get it running myself. When it is a $2000 rotating assembly to be matched with a machined block, I don't think I feel good doing it myself
Old Jan 25, 2016 | 12:07 PM
THE 383 admiral's Avatar
THE 383 admiral
The best Value to performance PR are trick flow. If you went with 1.6 with your Let's assume LE cam. you will almost Likely need .100 longer in length. But if you are sending you heads to Llyod. Have him check the roller tip to valve stem center position.
Old Jan 25, 2016 | 12:18 PM
THE 383 admiral
Not so true. I have over 11.1~ I tune. I do not NEED race gas. My engine does not PING. The LT1 has a great advantage with the reverse cooling the heads 1st... Also i believe the OP'r has the LTCC coil conversion you can remove the Rotor no longer needed. less rotational stress. The OE Cap is now Only a cover! that helps out with spark where the OE 1 coil fades out in the upper RPM range. This OP'r has also been advised to stay with a mild cam about stock compression to keep the cost down.
Old Jan 25, 2016 | 02:03 PM
aklim's Avatar
aklim
I thought all things considered, the reverse flow is good for 20 to 30 max?
Old Jan 25, 2016 | 05:24 PM
94VenomVette's Avatar
94VenomVette
Yea I dont mind going the LE2 Route on the heads, the cam has to be street friendly, i posted the specs i liked. I need the car to be a daily driver it wont be a drag car whatsoever. Heads coming off tonight, so im making some progress. Once the Heads and block go out ill know what im doing. As far as .100 in length Admiral 383 what are you implying...the pushrod length?
Old Jan 25, 2016 | 05:33 PM
aklim's Avatar
aklim
How are we defining "street friendly"? Are we talking small enough change that the ECM won't freak out or what?
Not sure why people always say that. I mean, if I were building a competitive race car to run pro, I'd certainly not be asking around an internet forum and have a professional builder do the job. Last dyno was about 420 at the wheels. I have AC, stereo, ABS, etc, and all the creature comforts it came with. I even installed a power seat for the passenger. Yes, the idle is a little lopey and higher than stock but I'd say it works for the street in that it doesn't spin the tires at the slightest twitch of my right foot.
Old Jan 25, 2016 | 07:19 PM
THE 383 admiral
That is correct. The +.100 push rod length tip. As you Mentioned the possibility of using 1.6 rocker ratio. you will not need a radical cam. A mild to moderate cam with a 383 build. Looking at Llyod's 1st cam listed. Should be more then enough to provide you 400+ HP especially with the LE2 heads Intake porting. 383 combo. I have his largest 110 LSA cam listed my idle is very lopy. But after i tuned it in. My combo is very streetable. This PCM in the 94- 95 has awesome tuning features. I only suggested a smaller cam to keep the bill down. keeping compression close to stock. & not Forcing you to upgrade gears along with a high stall.
Old Jan 25, 2016 | 08:02 PM
THE 383 admiral
PS Typically 383 rotate kits come with flat 2 valve relief. The LT1 heads are 58cc so a typical 383 will put you in the 11.5 - 12.0 compression ratio. The reverse cooling will handle this. But race fuel will almost be mandatory. Select your pistons 1st to keep you in the 10 - 11.0 range
I had a nice pair of 64cc 2.02 heads. from my previous L98 HSR build. I had my heads converted to use them on the LT1 reverse cooling.
Old Jan 25, 2016 | 08:33 PM
94VenomVette
Street friendly.....meaning not a crazy lopy idle thet affects vaccum and something i can run on 93 octane. I will tune it obvi. I want about 400Hp and be able to drive it. So i think with the LE2 heads and the cam i choose will suit my top ene just fine. I just need to select my bottom end components. I dont want to worry about pinging etc. this is not a race car. Its going to be w daily driver with some good pop. I would like miniumn 400hp
Old Jan 25, 2016 | 08:55 PM
94VenomVette
Also 1 pc or 2pc Rear main? Ive seen a lumanti kit but was for 2pc RMS
Guess ill also call callies after i
Get the block back and heads next week
Old Jan 25, 2016 | 10:18 PM
  #33
THE 383 admiral
you have a 1 piece rear main
Old Jan 25, 2016 | 10:58 PM
  #34
aklim's Avatar
aklim
You are going to need to match the intake to the heads and cam and exhaust and motor to start. Then you have to make sure your trans can handle the power and then the rear end has to have the right gear and strength. So, how much are we talking about spending? My calculation for good strength and all that isn't cheap,
Long block: $6K
Trans: Depends on whether it is auto or not
Rear end should be a D44 with gears: $4000
Dyno: $600-800
Headers and exhaust: $2000
Get ready for $15-20K for the whole deal or forget the thing/
Old Jan 26, 2016 | 12:33 PM
  #35
Red 91's Avatar
Red 91
Thatsa lotta money Ak! 'cuse me I gotta go get my injectors flowed
Old Jan 26, 2016 | 01:37 PM
  #36
aklim's Avatar
aklim
Fast, Reliable, Cheap. Pick any 2 you like. Soon as you build up a motor capable of putting more power than stock, you moved out of the design. Now that power finds the next weak link which is the trans and rear end. Do anything else and you are going to simply have one thing break after the other.
When I got my LPE 383 and brought it to Lingenfelter for tuning, after he got done, he TOLD me that my freshly rebuilt (by GM) stock trans would die within the year.
Old Jan 26, 2016 | 06:15 PM
  #37
94VenomVette
Well with a large amount of horsepower your going to break things, im not new to this. Never done a stroker before so needed some help and very happy with everyone chiming in. I know it will get exspensive but over time ill put into it. My main goal is to have engine back in the car by summer. Ill get my longtubes, injectors, tuning all done by then...if the trans goes it goes im actually thinking about the ZF6 and the dana 44 anyway. But i understand your thinking completely. 400-420hp for me in this is right were i wanna be. Pump gas 93 & a lopy but not too aggressive idle is perfect and already know what route im going to go. Im def going to have more questions but for now you all have set me in the perfect direction. Thanks!
To engine build question
Old Jan 26, 2016 | 06:31 PM
  #38
aklim's Avatar
aklim
Why toss the 700R4? If you wanted stick, you should have bought stick. Manual to auto is easier. No cutting. You can rebuild the 700R4 to hold power. I'm doing 420 RWHP with it. I also transplanted a D44 to hold the power. You can either get a D44 C-beam or drill holes in your C-beam.
Old Jan 26, 2016 | 06:45 PM
  #39
94VenomVette
Also should i send my intake out if the heads check ok to have them matched? I def want 1.6 Roller rockers aluminium. The heads are going out thursday as well. i have them completely taken apart to the bare no valves etc. Ill have Lloyd turn them into LE2 heads pending results.
I found a set of lifters from Comp. Looking for pushrods now. 7.300 what i need correct?
the bottom end I'm going to inquire about this weekend.
  #40
94VenomVette
4l60E i have.....I know I'm going with a D44 but the stick would be a nice addition i did stick conversions already so it aint a big deal
