I will be installing a new intake gasket on my 94! What else would you recommend replacing on a 22 year old car since were in there(clean the injectors? and put in new O-rings)? Any "no brainer" items you would just replace? Thank you in advance.
call Jon at FIC look to the adds on the right. he can set you up with bosch 3 injectors for not much more than cleaning your stock ones.
Thank you for the suggestion but $440 is alot more than cleaning the old ones since I'm doing it myself. Thank you again though as I am considering changing them.
if they are original multitech best to replace and if you call him I believe your under $200.
I think rebuilt ones are $220 or you can get yours cleaned for $105, if I am reading it right.
How are you going to clean and test the old ones without a flow bench?
