Question regarding engine power and physics...
Old Jan 29, 2016 | 11:56 AM
DanielRicany's Avatar
DanielRicany
Default Question regarding engine power and physics...
Hello everyone, I was just thinking to myself of a possible way to make more horsepower using only what's available us on what we already have to work with.
So, this is essentially what I was thinking. This is the fundamental question of the whole idea: Does momentum help with building more horsepower up top?
For instance, on a motor that makes power between 3000-6000ish RPMs, could we make more PEAK horsepower by optimizing the torque produced at low RPMs? I'm not talking about changing heads, intake manifolds, cam etc. What I am talking about is mostly in regards to tuning; maximizing the torque at low RPMs.
In my theory, if you could tune the engine to make more torque at a lower RPM by increasing spark timing and adjusting air/fuel ratio, could that as a side effect, create more momentum to make it easier for the engine to make power up top, and thus putting out more peak horsepower?
Old Jan 29, 2016 | 06:20 PM
84Z51J's Avatar
84Z51J
All other things being equal, shifting the TQ curve to significantly lower RPMs will reduce peak HP and the RPM at which it occurs, but provide more immediate off-the-line "grunt" (and vice versa). Good tuning will place your peak TQ/HP at ideal numbers & engine speeds ("ideal" depends on volumetric efficiency & application/load, of course), while providing the broadest possible area beneath the curve.
Old Jan 30, 2016 | 12:34 PM
bjankuski's Avatar
bjankuski
Short answer is no. Optimizing the power at every rpm position will maximize the power output of the engine over the rpm band but max power at 2000 rpm will not cause a higher power output at 4000 rpm, or whatever rpm you pick. Each rpm position is independent on the other.
Old Jan 31, 2016 | 01:40 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Not sure what the question is but it reads like u want to use the tune to make more low rpm torque and see if that increases the higher rpm torque and power.
Well u need to get the car to a dyno and watch what the tuner is trying to do Danny. On a street car the tuner will be trying to tune for max torque using optimum fuel mixture and optimum timing adv. Using the newer eddy current dyno's that hold the load accurately at desired rpm u can optimize fuel and timing for every 50rpm increment if desired - most will use every 500rpm. So what im saying is tuners are already doing this optimize maximize torque - but at all rpms, much like 84Z is trying to say.
An exception to this is some types of race engines and race circuit classes make to much low rpm torque and have to much wheel spin producing a lack of traction control - my camaro included. Many of these motors will reduce timing adv to kill some low end torque to prevent spin-outs.
FYI Greg Banish has some good books on EFI tuning. Hope this helps ya.
Old Feb 1, 2016 | 01:00 AM
blackozvet's Avatar
blackozvet
do you remember what happened last time there was an argument on here about horsepower v torque ??
Old Feb 1, 2016 | 09:51 AM
DanielRicany
Which one? This is not like any question I have asked before. Sorry if it seems that way.
Old Feb 1, 2016 | 12:06 PM
DGXR's Avatar
DGXR
I think we need to revisit the meaning of momentum. An object in motion stays in motion unless acted on by an outside force. So any force applied in lower RPMs only, will affect the crank (output) at lower RPMs only. High RPM output depends on its own point in the power curve, not any earlier point in the curve.
Old Feb 1, 2016 | 04:59 PM
blackozvet's Avatar
blackozvet
I was talking about this one,
https://www.corvetteforum.com/forums...sepower-6.html
volkswagons for life was copping a real beating in this one, things were starting to get very personal !
Old Feb 1, 2016 | 05:47 PM
DanielRicany
Mine is not really comparing the two, but rather a concern of using power generated at low RPMs to help it make it easier to generate power at higher RPMs by essentially in theory reducing the amount of force required to spin the crank. However many people have commented here who seem to disagree with the theory, which I accept 100%. But at the end of the day, really, that's all it is; a theory.
First time I'm seeing this thread. But it does remind me of one of my old threads...
To Question regarding engine power and physics...
