Fuel pressure regulator
Old Feb 11, 2016 | 02:35 PM
gregs86's Avatar
gregs86
Default Fuel pressure regulator
Does anyone know if the diaphragm kit are the same for adjustable and stock. Regulators
Thanks Greg
Old Feb 11, 2016 | 03:50 PM
gerardvg's Avatar
gerardvg
Thanks Greg
Yes it is just the regulator cover with the screw that is different, how old is the diaphragm?
They can tear with age and leak fuel into the sump via the vacuum hose, or leak through the hose onto engine and result in fire.
I recommend replacing the diaphragm as well, cheap insurance.
Old Feb 11, 2016 | 03:54 PM
gregs86's Avatar
gregs86
Thanks for the reply. I started my car this morning and raw gas was coming out of the exhaust. Pulled the vacuum line to regulator and there was gas there so I'm in the process of removing plenum now to get to the regulator.
Old Feb 11, 2016 | 11:53 PM
Cliff Harris's Avatar
Cliff Harris
You will need a Torx T-10 security bit to get the FPR cover off. I guess they didn't want people messing with it...
To Fuel pressure regulator
