1996 PKE Programing, not working.
I read this thread: https://www.corvetteforum.com/forums...tructions.html
I read this thread: https://www.corvetteforum.com/forums...rn-on-pke.html
I read this thread: https://www.corvetteforum.com/forums...l-pke-faq.html
And several others.
I have a 96. Car was missing the remote / fob when I bought it.
I ordered a new remote / fob from ebay.
3. Push TRIP OD0 on the Driver Information Center twice.
4. Within five seconds, press and hold FUEL INFO until the PASSIVE KEYLESS ENTRY light comes on.
The light never comes on?
The only thing I have not tested is if the light is burnt out. Is there anything else that can disable the system? If the light was burnt out, it should still program the remote. I tried with no luck.
And several others.
http://www.ebay.com/itm/1993-1996-Ch...ZWgraJ&vxp=mtr
And several others.
If it still won't light up (since you have already thought of the burned out bulb) it's likely that the PKE receiver is not working. Unfortunately that is fairly common as these cars get older, I've never replaced one but I understand it is pretty difficult. There is nothing that would disable the programming procedure. When people ask about getting a fob I recommend that they go through the programming procedure first to make sure that the light comes on before buying a fob.
The Trip and Fuel buttons work fine.
Remote is not needed to get to program mode, so if remote is bad the light would still come on.
You can get the remote/fob on ebay. I paid $135 for mine. Sounds like I may be selling it.
I have not pulled the dash apart to check the light. Getting a new deck in a few days. Figured I would wait till then.
26, 40 and 42 are fine.
40 is the radio, was the bose system needed for the PKE? That seems strange.
Would someone go hold down on there FUEL INFO button and tell me if there dash cycles through the display options.
While holding down mine loops goes through each option on the dash, like Im pushing the button over and over.
If this self test does not work properly, you will not be able to program the car.
If the self test fails, then the PKE receiver is bad or the lamp. Unfortunitly the receiver is usually defective.
Great, ok then I guess the cycling is normal operation.
I still have not checked the bulbed. I am waiting for the new head unit before I take the dash apart. Should be here any day.
I don't know if the PKE will come out of sleep mode if power is removed from it by disconnecting the car battery or pulling the proper fuses.......never tried it.
