C4 front shocks
Old Apr 2, 2016 | 08:18 PM
mark501w's Avatar
mark501w
6th Gear
Default C4 front shocks
Did one side ( replacing with Bilstiens) lowered suspension the shock cover rattles around like a bell with the suggested squish of even with washers. So I put a load on the suspension & tighten the lower bushing so the cover doesn't rattle. The upper bushing sure is smashed when the load is removed
Old Apr 5, 2016 | 11:43 PM
blackozvet's Avatar
blackozvet
Im surprised no one has replied to this,
do you have a pic of how it looks ?
you do have to do them up pretty tight and get some squish on the rubbers.
Old Apr 7, 2016 | 08:38 AM
WVZR-1's Avatar
WVZR-1
I saw the post and there was so much information "not posted" by the OP I thought I'd just maybe watch and see what developed. Without "numbers" there's little help, NUMBERS = year and part number of product.
OP - you need to mention 1. The "year" and 2. the part # of the shocks.
Snapshots maybe -
Old Apr 7, 2016 | 03:58 PM
mark501w's Avatar
mark501w
6th Gear
Default C4 shocks
88c4 Bilsteins #24011310 <br >
Old Apr 7, 2016 | 05:47 PM
WVZR-1's Avatar
WVZR-1
Your shocks by part # are a match to what Bilstein says is correct for an '88. The '88 is a "single year" application. Originally the insulators would have been 2 different part # and been very different for under the suspension member and a different above. The retainer/washer would have been the same. Aside from the "SQUISH" you mention the install looks correct. Have you done the other side? Are both of the insulators the same or does one definitely have a "shoulder" that indicates it's for under the suspension member and would use the "shoulder" to center it in the bore.
A stack like this I would have expected:
Name:  Front shock base.png
Old Apr 7, 2016 | 06:39 PM
artvette's Avatar
artvette
If you're worried about the "squish", get some poly insulators.
Old Apr 7, 2016 | 07:31 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
In stead of worrying about the squish, maybe its time to replace and fill the brake fluid?
Old Apr 7, 2016 | 07:44 PM
WVZR-1's Avatar
WVZR-1
That's actually the first thing I noticed and left it alone. I figured it was on the "to do" anyway. The shock insulators, if the lower is shouldered then all's well.
Old Apr 8, 2016 | 11:28 AM
mark501w's Avatar
mark501w
6th Gear
Default C4shocks
Breaks are next , both look the same. I guess I'm not used to the idea of the shocks limiting suspension travel.
Old Apr 8, 2016 | 11:35 AM
WVZR-1's Avatar
WVZR-1
If you haven't done the other side yet maybe post snapshots of the insulators.
Old Apr 8, 2016 | 11:38 AM
mark501w's Avatar
mark501w
6th Gear
Default Mines
<br >
Old Apr 11, 2016 | 11:15 AM
hcbph's Avatar
hcbph
I don't if this might be your issue or not but not too hard to check. I once got a set of shocks for a vehicle that had the wrong bushings in the kit. They apparently didn't fill the mounting hole properly when tightened up, they rang and clunked so much it was embarrassing. They let the shock 'flop' around when driving and hitting a bump etc. After much frustration, I only found it when I took one off and compared the parts to the original. Quick call to the vendor got a set of replacement's in the mail (before the internet).
Might be worth checking. Good luck
Old Apr 11, 2016 | 07:54 PM
2ooo-C5's Avatar
2ooo-C5
his bushings are correct. I replaced mine 3 or 4 days ago.
They are a little different then factory, but they will work fine.
I tightened mine a little less then his. So I have a little less squish.
Yes the shocks limit the suspension travel on the corvette.
I also though it was weird to have to support the lower control arms to put the shocks on.
Old Apr 11, 2016 | 11:20 PM
mark501w's Avatar
mark501w
6th Gear
Default Shocks
Thanx for the info
Old Apr 11, 2016 | 11:21 PM
mark501w's Avatar
mark501w
6th Gear
Default Shocks
Thanx for the interest
To C4 front shocks
