Intake for a 427
also will 42 lb injectors feed this engine?
here is the engine specs.
http://www.jegs.com/i/Blueprint+Engi...272CT/10002/-1
Thank you for any input you can provide.
That, and also having a 427 Corvette.
Since Blueprint dynos it before they ship it, I will put the car on the dyno to see how the miniram affected the power curve.
I guess i'll make do with "only" 540hp
The cam is a trade off for power, driveability and reliability, but that said that 540HP engine would easily run low 11's to high 10's in a halfway decently set up car.
I do not believe the miniram will have any problems at all meeting the advertised HP and TQ numbers. It won't follow the power curves perfectly as they used a Single Plane Intake in testing but the peak numbers will be very close.
Will
Are those blueprint heads a version they researched and created? Engine masters series by hot rod magazine on youtube has been mentioning them. They don't have bad things to say about them. I'm not sure if Cuisinartvette still works heads or intakes but I bet if you sent your miniram and heads off this crate to him, he could find some more horsepower to put on the table for you.
We saw your post and wanted to thank you for your purchase of BluePrint Engine's 427 small block! Remember, we are here to help if you have any questions on our products.
Some of the other members asked why the 427 was only making 540 hp.
The easiest answer is that BluePrint Engines builds street performance engines. Our crate engines are not built to be race engines. This means that we design our engines for our customer base who want a great, reliable engine that does not require a ton of maintenance. They want engines that they can get in and drive on a Saturday morning without worrying about doing a bunch of work on it the night before.
We build the engines to have great street manners, use hydraulic camshafts, run on 91 octane gasoline, need less than a 3000 rpm stall converter, and have our 30 month/50,000 mile warranty. These builds are designed for great low to midrange power and torque where street driven vehicles can take advantage of it.
It is easier than ever to get a 427 small block over 600 hp with today's cylinder head and camshaft technology. But, building these engine often require solid roller camshafts. These require bronze gears on distributors that need changing every 10,000 miles, need regular valve adjustments, and replacing valve springs and lifters quite regularly for a long life of an street driven engine. These cam profiles often require 3000 + plus stall converters and are can be difficult to drive in traffic.
There also seems to be some confusion about our cylinder heads and blocks. BluePrint Engines has grown to the position that we now employ our own design and engineering staff, who has been designing our own engine products. We are moving from just being a machine shop to a fully realized engine manufacturer. We did this for several reasons. A. better control over inventory and especially quality. B. We are able to design in details we wanted for the engines we are building. C. Reducing cost, which we then pass to the customers! While we do not have our own foundries, we do own the tooling that is being used to make our products.
Scott Liggett
BluePrint Engines
1(800)483-4263
info@blueprintengines.com
www.blueprintengines.com
I am excited for the 427 and counting down the days until I get to drop it into my Corvette. I am hoping to surprise a few people with it. i do have questions:
what should I set my rev limiter at?
how much timing should I allow?
540 is alot of HP in a C4. If legit that's around 470 rwhp. Certainly nothing to sneeze at....My 421 was just shy of that and it pulled pretty hard!
What rwhp did your 383 make?
