Brake dash warning light
Old Apr 13, 2016 | 05:45 PM
FOR PLA's Avatar
FOR PLA
Centering the pressure bias piston should be the last step. Move it to center with small screwdriver and replace switch. Job done.
Old Apr 13, 2016 | 05:49 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by LarryShivers
The MC switch is the one I was referring to. Once it is unplugged the light goes off.
That's what I thought likely. Did you set the E-brake before starting the project? Maybe check? Maybe disconnect the switch at the E-brake and test?
I understand the "SHOULD BE" for sure.
Old Apr 13, 2016 | 05:52 PM
FOR PLA's Avatar
FOR PLA
I am assuming bleeding at each wheel caliper was done properly. Then move the pressure switch to center.
Old Apr 13, 2016 | 06:04 PM
LarryShivers's Avatar
LarryShivers
I have repositioned the piston two times with the same results. Light goes off but once brakes are applied the light is back on.
Old Apr 13, 2016 | 06:31 PM
FOR PLA's Avatar
FOR PLA
Rebleed each caliper in proper order then reset bias switch. You have air in system some where.
Old Apr 13, 2016 | 10:27 PM
LarryShivers
Will start back on these next week. Leaving town for several days tomorrow morning. Thanks to everyone for your advise. I'll update next week.
Old Apr 13, 2016 | 11:44 PM
Cliff Harris's Avatar
Cliff Harris
The last time I bled my brakes I got the BRAKE light. It went out after I pressed the brake pedal down firmly as far as it would go.
Old Apr 14, 2016 | 04:06 AM
WVZR-1's Avatar
WVZR-1
...that is precisely what the FSM mentions needs to happen.
Old Apr 17, 2016 | 07:40 PM
LarryShivers
Originally Posted by antfarmer2
Harbor freight has a $20 one that works.
Got a vacuum pump bleeder from Harbor Freight and bled all wheels again. Got a better pedal of brakes but the light is still on. One possible problem I did see was that the right front when bled took a long time to get fluid to flowing. The rest of the wheels filled up the pump container with fluid rather quickly with the vacuum pump pressure declining slowly. The RF pump pressure went down quickly with very little fluid flow. I have never had any problems with the brakes pulling either way but this fluid flow is confusing.
Also are there any other bleeder besides the 4 wheels?
Old Apr 18, 2016 | 12:18 AM
antfarmer2's Avatar
antfarmer2
Sounds like your rubber line is swelled up constricting the flow might be time to change them. Any sign of leaks?
Old Apr 18, 2016 | 09:20 AM
LarryShivers
Will check today. Strange though since there wasn't a problem before I changed the Master Cylinder.
Old Apr 18, 2016 | 01:32 PM
LarryShivers
Did you push it fully on the bench? Might still have air in it. And is it full of fluid.
Bench bled it until no air could be seen in the lines into both tanks. Have maintained full level of fluid during bleeding.
Bleeder was bad. Swapped the left and right bleeders and vacuum bled the right side. Vacuum pressure went down slowly and fluid quickly drained into the container. I repositioned the piston and the light was off until I applied the brakes. Is there anyway to check to see if I have a bad MC? I don't know what else to try except bleed the whole system again.
Old Apr 18, 2016 | 06:25 PM
  #33
antfarmer2's Avatar
antfarmer2
Need a new bleeder I would think you got some air in there swapping them.
Old Apr 19, 2016 | 06:23 PM
  #34
LarryShivers
Replaced the bleeder and vacuum bled all wheels again. Repositioned the piston and light is off until brakes are applied. I also bled each wheel manually with someone pumping the brakes. No air.
One thing new I did see. I have all 4 wheels off the car - makes for easier bleeding. I cranked the car and put it in drive. The front wheels locked down but the rear wheel will not lock down unless you really stand on the brakes.
Evidently I have unequal pressure between the front and the back but what is causing it? MC has been bled twice. All wheels have been bled at least 5 times.
Could it be the proportioning value in the MC causing the problem? If so how would you check it?
This is a new Cardone Select MC from Rock Auto.
Old Apr 19, 2016 | 09:19 PM
  #35
antfarmer2's Avatar
antfarmer2
The front wheels need to be turning for the brakes to work right. Does the piston move off place each time the light comes on?
Old Apr 19, 2016 | 10:55 PM
  #36
LarryShivers
Yes. Every time I have checked it (4 or 5 times) the piston is off center.
Old Apr 20, 2016 | 12:54 AM
  #37
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The switch needs to be removed and once removed you can access the pressure equalization piston. This small piston needs to be centered in the master cylinder housing. Bleeding moves the bias switch forward or back. Move this small piston to the center and reinstall switch. The warning light will go out.
BINGO!
Pull the switch and look into the hole. The shuttle piston has a ring groove that should be centered. The switch has a small pin that rests in this groove. If the shuttle moves from a drop of pressure on one side the shuttle pushes up on the switch. If the o-rings on this shuttle leak. Fluid comes out of the switch.
To Brake dash warning light
Old Apr 20, 2016 | 12:55 AM
  #38
JrRifleCoach
You can move the shuttle with a small flat screw driver tip.
Old Apr 20, 2016 | 09:23 AM
  #39
antfarmer2's Avatar
antfarmer2
Looks like the problem is found! I have never personally messed with one. Hope someone can tell you why.
Old Apr 20, 2016 | 09:54 AM
  #40
LarryShivers
Originally Posted by JrRifleCoach
BINGO!
I have removed the switch several time and manually moved the piston grove to the center. Light goes off until brake pedal is pressed. Why does it keep moving? There is no brake fluid in the switch cavity. What can I do that I haven't already tried?
Another MC??
