Crossfire improvement advice.
In the quotes, that was all very much over my head. I'll have some more patience on this, and I'll let the thread ferment for a few days and see if I can pick up any more opinions on the matter.
if all else fails, I'll just chuck a blower on a crate SBC and call it a day lol.
I know how engine controls work. I agree that "it is always wise to tune the system" -that is stating the obvious. It's a red herring argument.
Is it Necessary to meet the criteria? No it is not. It may be the "best" way, but I and others have proven that it certainly isn' the only way. "Hill billy" or not, my way worked and cost less too.
"my head starts swimming about 2 TB vs 1"
Yikes. That should be a red flag to the OP. 2 TB's mounted separately on the plenum is functionally no different than 1 TB assy, that has two "holes" in it (two throttle plates), be it a MPFI like TPI, or a CFI compared to a standard 2 bbl TBI truck motor. A TB is an air valve and that is all it is. Doesn't matter if they're next to each other on the same shaft or mounted on opposite sides of the plenum. The stock CFI throttling system functions exactly the same as any other GM TBI: it has two injectors, one TPS, it has two IAC's that are controlled by one driver...as far as the ECM is concerned, it doesn't "know" or "care" that the TB's are in separate castings.
Changing the ECM and making it tunable is certainly desirable....everyone would surely love to do it that way, w/unlimited time/ resources. I sure would have like to. But, the realities of real life, time/money frequently limit the scope of our projects and so we have to get creative as to how we manage them, in order to meet our criteria.
Guys, CFI/EFI did a massively ported stock intake, cat back exhaust, "free tuning" (the very same tuning that Mr. *****'s lambasts), and a converter. His car would run in the 13's at sea level. His money invested was nearly nothing. Car idled like stock, driveability was like stock (only more so), RPM range was extended 1000 RPM, fuel mileage remained "like stock " ~24 hwy. What criteria was he missing out on? Something, I'm sure....but something insignificant.
Then there is me; I started w/an '83 Trans am, 305 CFI/auto. I changed it to a stick, did the "free mods"/tuning to the stock engine, added Edelbrock "tubular manifolds" and went 14.5/95. The CFI TA was originally a mid/high 15 second car. I went 14.5//95 doing the changes MR. *****'s call's "hill billy".
I put in a 350, made appropriate changes and enjoyed that engine for a few years, then put in a SBC 400, ported the intake, bored the TB's installed a 224/234 cam, headers, exhaust, roller rockers...among other things. Running on the stock ECM/chip/tune, that car would go low 13's/105ish. Car idled like stock, driveability was like stock (only much more so), RPM range was extended 1000 RPM, fuel mileage remained "like stock " ~24 hwy. What criteria was I missing out on? Something, I'm sure....but something insignificant.
Tuning is the best way, but not a necessity when keeping things (especially the cam) mild. This is from a guy who has done it.
I certainly miss "CFI-EFI" and the ole "RACE ON" ..............
There's over 10 pages of threads where "CFI-EFI" was a participant. Many very good reads - all interesting - some locked LOL
A search from "SEARCH THIS FORUM" button above "THREADS/POSTS" using the "ADVANCED SEARCH" and user "CFI-EFI" will surface them. Good reads and many smiles!!!
Use this link to search from, it will collect all C4 sub-forums
https://www.corvetteforum.com/forums...-1984-1996-19/
That is the best place to originate any search if it's C4 related .. covers all sub-forums.
And if i update the fuel system with a higher pressure regulator and the higher pressure pump, what would be the next step from there?
I apologize for my ignorance, this is my first build and my biggest learning experience so far and its a tad overwhelming for the moment.
When I first got my 84 years ago I was trying simple things to improve the performance, this was before the internet forums & the vette mags were useless, I made up an open air filter set up for each tbi. Even on a warm summer day that thing would sneeze every time I accelerated hard, telling me it was running lean. I did not know about the fuel pressure mod. The car was stock at the time and ran fine with the stock lid on it.
I think your first step is to get a die grinder & get to work. That's the most bang for the buck mod on a cfi engine.
I sure miss him too. He was a good man.
*Do it the...ahem, "hill billy" way and enjoy it for years, as CFI-EFI and I (and others) did, successfully
*Do it the...ahem, "hill billy" way in the short term, then later find a tunable $olution as funds/time present themselves
*Go all the way at one, build an engine, decide on a tuning/engine control system, then buy that and tune.
Some posters are saying "it can only be done one way" "Any other way is wrong". I'm telling you, from 1st hand experience, that isn't true, and I'm telling you, not to convince you to do it the way that *I* did, but rather so that you're enlightened and you can make a proper, informed decision for YOU.
Low 13's, 24 mpg, stock like idle and drivability. IDK what others' criteria is, but at the time, that was mine and I met it with a stock 305 ECM/chip/tune.
Criteria *****. Meet the criteria.
That seems a bit absurd in this thread. OP wants to spend, what, ~$1000? and put in maybe 10 hours of work to get some low hanging fruit from his car? And you're suggesting a fairly radical engine swap (one you haven't made yourself, I might add) to achieve some preconceived RPM? What RPM? A well ported CFI intake will make useable power to ~6000 RPM on a 350. What RPM is "the right one"?
In fact, based on my own experience, I'd say that they're far more reliable than other GM OEM injectors (cough! multec cough).Actually carbs typically run 5-7 PSI or so....TBI spec in automotive form is 9-13 PSI -about twice that of a carb.
Originally Posted by dr_gallup
I understand the desire to keep it stock looking but you really are tying one hand behind your back keeping the TBI injectors. These were GM first attempt at electronic fuel injectors and they are pretty bad.
Absolute and complete HOGWASH. Cite your source. Clarify, precisely how those injectors are "pretty bad".
Be careful adding fuel pressure, they will become erratic or stop working completely with fairly modest pressure increases. That can be overcome with a higher current driver. They are also not very consistent injector to injector either so make sure you buy your high flow injectors from a good injector shop that can send you test data for the actual injectors you buy.
More total horse ****. The injectors are way better than good enough, to make for a great street driven car. Are you aware that those very same injectors -the ones you say are "pretty bad, stop working at modest pressures, not very consistent"...those same injectors have been used in marine application Chevy V8's, at pressures up to 30 PSI (not that one needs to run those pressures in a car to meet the criteria) while making over 300hp? And they have been used as OEM marine equipment right up into the late 2000's? That's over 25 years of OEM automotive and marine use. They may have some shortcomings, but none that matter to guys looking to add a cam, exhaust and ported intake to their car!
We supply some of the marine engine builders and I'm very unimpressed by the quality of their engineering. Way below the standards of automotive OEM's. The fact that they kept using such a lame system for so long does not surprise me. This system has one positive attribute, it's cheap because you only need one or two injectors and a relatively low pressure pump. Yes it's good enough for it's day. That does not mean it's very good.
I will agree with your snide comment about Multecs I's, not to mention the CPI and SCPI abortions Delphi foisted on millions of unsuspecting SUV and truck owners. So maybe I shouldn't say the Maxi TBI are the worst injectors, Delphi did make some crap!
I'm not telling the OP not to follow his pursuit of higher performance with the cross fire TBI, just point out some potential pitfalls.
Toss out some Patent#'s - tell us about yourself - if you're GREAT introduce yourself.
Model #'s of your '80+ adventures?
