Need help!!!
Old May 10, 2016 | 10:49 PM
  #41
antfarmer2's Avatar
antfarmer2
Originally Posted by rpenajr4
Nope, koeo sits at 34 psi
Great found the problem now to find the cause.
Old May 10, 2016 | 11:46 PM
  #42
rpenajr4's Avatar
rpenajr4
With key on engine off it sits at 34
Old May 11, 2016 | 02:40 AM
  #43
rpenajr4's Avatar
rpenajr4
Ok so I changed the fuel gauge with another I had now it reads 42 with key on engine off but the pressure starts to drop...also with the car running its at 35psi...when I reinstalled the fuel rail I could tell the injectors are not sitting flush within its cup of the intake...and I can't push further in since the rail is flushed with the intake. So could it really be the injectors that are faulty?
Old May 11, 2016 | 06:15 AM
  #44
antfarmer2's Avatar
antfarmer2
Ok hopefully we will know today.
Old May 11, 2016 | 04:14 PM
  #45
rpenajr4's Avatar
rpenajr4
Well bro today in the morning I turn the car on went and stayed at 40 and I turn on it goes to 35, took it for a spin and the car just sputtered as if it was short on fuel or flooding...
Old May 11, 2016 | 04:31 PM
  #46
antfarmer2's Avatar
antfarmer2
There is another thread in general with injector swaps. Have you gotten the 24s yet?
Old May 11, 2016 | 04:33 PM
  #47
rpenajr4's Avatar
rpenajr4
No not yet could be here by today, if not then tomorrow for sure
Old May 13, 2016 | 04:38 PM
  #48
rpenajr4's Avatar
rpenajr4
Ok so I got the injectors, the car has a rough idle and the o2 are running lean both banks. Engine stalls and stumbles when it has a loan and shuts down automatically
Old May 13, 2016 | 04:39 PM
  #49
rpenajr4's Avatar
rpenajr4
Does it take time to relearn the 24lbs injectors or the o2's went bad already
Old May 13, 2016 | 05:06 PM
  #50
rpenajr4's Avatar
rpenajr4
Plus now my gauge is reading less than 20 at the rail while engine running
Old May 13, 2016 | 06:06 PM
  #51
antfarmer2's Avatar
antfarmer2
Just a WAG but in my first post I asked about the o2s. You say they are running lean now. So could they be bad and telling the puter it is lean and dumping way to much fuel? I believe your came with 22lbs injectors but could be wrong.
Ok just read your thread again. Need to confirm your fuel pressue with key on not running and running.
Did you buy the injectors from slick *****? Or Jon at FIC?
Did not see where the o2s were changed.
Old May 13, 2016 | 06:27 PM
  #52
rpenajr4's Avatar
rpenajr4
I'm a complete moron, the reason for the sputtering was because it was low on fuel, didn't read the digital and it was on reserve
Old May 13, 2016 | 06:35 PM
  #53
rpenajr4's Avatar
rpenajr4
Waiting for my wife to get home to go and dump some gallons of premium gas and check it it out if it runs and purrs like a kitten
Old May 13, 2016 | 06:48 PM
  #54
antfarmer2's Avatar
antfarmer2
Yes fuel will help but mine will run fine on reserve.
Old May 13, 2016 | 07:51 PM
  #55
rpenajr4's Avatar
rpenajr4
Yea it was on reserve and it was dying on me wouldn't stay on had less than 10psi on the rail, had a gallon poured it in and the psi raised quickly to 35 on and 40 off
Old May 13, 2016 | 07:57 PM
  #56
MrWillys's Avatar
MrWillys
Good luck I hope it works well for you. I do not sell injectors ant man.
Old May 13, 2016 | 08:14 PM
  #57
rpenajr4's Avatar
rpenajr4
Yea I hope this cures all the issues, it's becoming a thorn in my life
To Need help!!!
Old May 13, 2016 | 08:15 PM
  #58
rpenajr4's Avatar
rpenajr4
As far as the tps having a .58v at close throttle and 3.18v at wot is that accurate
Old May 13, 2016 | 08:25 PM
  #59
antfarmer2's Avatar
antfarmer2
the link you sent me, do I just order it direct or do I need to specify any new info
Sorry ***** my mistake I though you sent him a PM link from this.
Old May 13, 2016 | 09:15 PM
  #60
rpenajr4's Avatar
rpenajr4
Ok so I put fuel the car responded awesome, even during close loop but when the car hit 230 it started bogging down on me. I went and bought a 180 thermostat which I plan on installing tomorrow...but now while I was driving it the asr turned on hooked up my scanner and gave a trouble code of tps signal out of range which brings me to my previous question about tps signal voltage. I get .58 at close throttle and 3.18v at wot is that normal?
