Does anyone have a diagram/schematic that shows the vacuum lines for cruise control on an '86? A lot of my vacuum lines have rotted away. Only recently getting around to fixing some of this stuff. Thanks for any help!
Looks like it is time for a FSM two book set on ebay now for $60.
Thanks...but I actually do have it somewhere. I moved not too long ago, and not sure where it is at the moment. Will get to that box sometime I'm sure.
Just an additional question for anyone that might know. In the photo kindly provided by "Xrav22"...right above where it says "front of vehicle" there is a black section between the pink colored lines. Is this a "check valve" etc. of some sort, or just a vacuum "tee"? Most mine is rotted away, so it's been hard to tell. Thank you!
For the hose going to the pedal just reach up and cut the hose. Then cut it long ways two inches and ele tape a wire deep in it and lube the hose pull it through and back. Then use a connector. Saves tearing the car apart breaking the switch and getting stuck while hitting your head.
