What should I do next?
Sep 10, 2002 | 02:17 PM
Hey, I just got my corvette a few weeks ago and I am loving it. I have gotten the itch to modify it some more and was wondering what I should do next. Also, I only have $700. Thanks
Sep 10, 2002 | 02:27 PM
Re: What should I do next? (JF_AH_64)
If emissions aren't an issue you can ditch the shortie headers and get long tubes.
Otherwise I would see if you could find some 4.10 gears.
Sep 10, 2002 | 02:57 PM
4.10s
Sep 10, 2002 | 04:59 PM
Re: What should I do next? (vader86)
thanks, would that give me the best performance increase for the money, also would nitrous be a good step
Sep 10, 2002 | 05:13 PM
I paid around $700 for my 4.10's & installation.
[Modified by STL94LT1, 9:15 PM 9/10/2002]
Sep 10, 2002 | 05:15 PM
Re: What should I do next? (STL94LT1)
nm
[Modified by marthpodi, 4:16 PM 9/10/2002]
Sep 10, 2002 | 05:39 PM
St. Jude Donor '04 & '05
Why??????
Work on other performance goodies....plenty to chose from...
get all the catalogs....should keed you busy for awhile..
tony :cheers:
Sep 10, 2002 | 10:40 PM
Re: What should I do next? (oldace84)
so 4.10s sound like the way to go, so do i need just the ring and pinion or do i need the entire housing :confused:
Sep 10, 2002 | 11:09 PM
Since you already have a D44 carrier, you should only need a new ring & pinion
Sep 10, 2002 | 11:12 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
you have the best dif. now so all you need is the gears I just had some 3.73's put in today $497.68
[Modified by fsr402, 10:12 PM 9/10/2002]
