Muffler recommendations
Old Jul 31, 2016 | 05:07 PM
RVY's Avatar
RVY
Default Muffler recommendations
I'm trying to QUIET DOWN the toy. My neighbors don't have to hear me coming home in the evening. Loss of horsepower is not a problem. I have enough as it is. Brand names would be appreciated. Stainless would be desired. Any real experience would be appreciated. The ears are starting to hurt.
Old Jul 31, 2016 | 10:44 PM
aklim's Avatar
aklim
What do you have now?
Old Aug 1, 2016 | 04:00 PM
84wuzmy1st's Avatar
84wuzmy1st
Quiet Flow SS, Walkers. Rock Auto.
I am assuming you are replacing after market mufflers and not factory.
Old Aug 1, 2016 | 04:02 PM
84wuzmy1st's Avatar
84wuzmy1st
Just noticed you are in Florida, what year is your car? I actually find the Quiet Flow mufflers too quiet. Do you have any idea what exhaust your car has now?
Old Aug 1, 2016 | 04:15 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by RVY
93 LT-1, 383w 9-1compression/Vortech T trim/ CC cam/ etc pushing out 595rwhp @5700 rpm/571 max torque--non intercooled.
I'd recommend stock C6 base mufflers. They flow a lot (don't seem to affect power on the 400 hp LS2) and they're ridiculously quiet.
Old Aug 6, 2016 | 03:59 PM
L.V. Vette's Avatar
L.V. Vette
My stock 91 auto came with Flowmaster 50 series mufflers. They have a nice rumble at idle and while on the throttle. Not the prettiest tips, but they are ok. Also, they do not drone, which was a relief to me as I had a Trans Am with aftermarket exhaust whose drone was very annoying.
Old Aug 6, 2016 | 04:22 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't know....I don't think that any aftermarket muffler is going to be very quiet with "383w 9-1compression/Vortech T trim/ CC cam/ etc pushing out 595rwhp @5700 rpm/571 max torque--non intercooled"
Old Aug 6, 2016 | 04:23 PM
aklim's Avatar
aklim
I feel your pain. We can swap the cars if you like.
Old Aug 7, 2016 | 10:55 PM
toricred's Avatar
toricred
I'm looking for quieter mufflers for my 96 CE. I believe everything is stock right now and the mufflers are just over a year old from Corvette Central (OEM spec'd), but a couple of months ago they suddenly started being extremely loud a couple of months ago. I think something came apart inside, but I don't know. I've had it checked for leaks, but nothing was found. I'm thinking some of the mufflers suggested here might be a good fit. I'll start a separate thread tomorrow and stop hijacking the thread.
Old Aug 8, 2016 | 09:37 AM
RVY's Avatar
RVY
Default Thank you
Thanks for the various comments. I located a "stock" system not far away here in Florida. I couldn't find suitable mufflers with the inlet as well as muffler length I felt I needed. After 20 years the B&B triflo is coming off the toy. I hope my ears notice the difference.
Old Aug 9, 2016 | 08:18 PM
steven mack's Avatar
steven mack
I have also used walker Quiet Flow mufflers .They are a direct fit work great.Before the Walkers a friend gave me a cheap after market set.The resonance and noise was so loud they would give me a headache in ten minutes of driving.
Old Aug 10, 2016 | 02:03 PM
qwiketz's Avatar
qwiketz
I just fired up my car for the first time in a while and the B&b is quite loud. My cats are blown out so that doesn't help.
I was thinking of swapping out the resonator with one of the 3" internal x pipe dynomax mufflers to see what that did for performance reasons. However, I would imagine it's got to flow better than the B&b and the sound might be more mellow since some people use this muffler alone. Combined with the mufflers, I'd think it might be a little more mellow.
Old Aug 13, 2016 | 09:42 AM
Strick's Avatar
Strick
I'm surprised nobody mentioned Corsa. The debate used to be between B&B and Corsa. For quiet no drone, Corsa seems to be the best. B&B worked for me, but I ran into a problem with the 3" system as I have a convertible with the cross beams. Now I just run muffler elims with the stock resonator, I like a little noise.
To Muffler recommendations
