Relay or switch?
Old Aug 16, 2016 | 12:26 AM
BOOT77's Avatar
BOOT77
Default Relay or switch?
Turn the key on and pump kicks on and good psi at rail but doesn't start until oil psi is about 5. I thought if it had good psi at the rail with key on then the relay is good?
Old Aug 16, 2016 | 01:10 AM
antfarmer2's Avatar
antfarmer2
Clean the throttle body.
Old Aug 16, 2016 | 03:36 AM
BOOT77's Avatar
BOOT77
It's clean, new iat and tps checked
Old Aug 16, 2016 | 06:19 AM
WVZR-1's Avatar
WVZR-1
OPS is only a "BACKUP" for the fuel pump. ECM controls the relay. Cliff has some corrected wiring schematics from an '86 FSM that you might compare to your '87? I think. If you have SES at "key-on/no-start" then the ECM is powered so you would check the relay supply from the ECM. Remember it's only a 2 second thing.
A couple years ago Cliff summarized quite well the operation in this thread for another user. It's a very god read regarding fuel for an L98 with a '165 ECM
https://www.corvetteforum.com/forums...post1585861532
Old Aug 16, 2016 | 08:32 AM
BOOT77's Avatar
BOOT77
It's an 86, forgot to mention the year. Car also as has VATS bypass in the chip n I did the starter. I honestly don't rem when it started, I've been off-n-on working on the car Cold start injector is deleted in the chip also.
Old Aug 16, 2016 | 08:46 AM
WVZR-1's Avatar
WVZR-1
You're all set then just use Cliff's modified diagram for diagnostics and operation. Best of Luck!!!
Old Aug 17, 2016 | 02:35 PM
BOOT77's Avatar
BOOT77
Well read that thread and went out n pulled the 3amp emc/ign fuse. It was good but it had a bad connection because soon as I put it back in the problem went away, so I replaced it with a new fuse anyway. idk is the SES light was on before and I think it wasn't but it is now.
Old Aug 17, 2016 | 08:01 PM
BOOT77's Avatar
BOOT77
Nope doing it again and SES is still on
Old Aug 21, 2016 | 04:18 AM
RICHARD TILL's Avatar
RICHARD TILL
good and fully charged battery?
Old Aug 21, 2016 | 04:41 AM
BOOT77's Avatar
BOOT77
Yah cranks like a champ! It started good a handful of times since the fuse so I'm thinking loose wire at the block and gonna pull the dash apart soon for something anyways.
To Relay or switch?
